RCD 6.0L & 6.4L Ford Bypass Filtration and Relo. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BogginF350, this thread has received 20 replies and been viewed 7504 times.
post #1 of 21 (permalink) Old 09-21-2009, 01:11 AM Thread Starter
BogginF350's Avatar
We have finished testing on our bypass filtration and oil filter housing relocation kit. Both kits are avialable for the 6.0 and 6.4 trucks. We also have two different base mounting variations. One locates the filter base on the outside of the frame and the other behind the transfer case. The transfer case option will be a small upcharge due the the -12 180 degree sweeps. Initial install time was 45min. The bypass filter will catch anything over 3microns which should help spool valve issues on the 6.0 considerably. The solid T6 aluminum base is bored and sized accordingly to allow the oil to flow past the 3micron filter in the event it ever becomes plugged. And like always it is made here in Peoria, IL.
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #2 of 21 (permalink) Old 09-21-2009, 01:18 AM Thread Starter
BogginF350's Avatar
Pics
Name:	Adapters And Base.jpg
ID:	22039   Click image for larger version
Name:	top pass side view.jpg
ID:	22040   Click image for larger version
ID:	22041   Click image for larger version
Name:	Base Side view.jpg
ID:	22042   Click image for larger version
Name:	Outside the frame.jpg
Josh Davis
6.0L Ford
6.4L Ford
(309) 699-2488
post #3 of 21 (permalink) Old 09-21-2009, 01:19 AM Thread Starter
BogginF350's Avatar
more
Josh Davis
6.0L Ford
6.4L Ford
(309) 699-2488
post #4 of 21 (permalink) Old 09-21-2009, 01:30 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
so this isn't really a bypass system like others but instead just a relocation???? Looks like a great setup
2003 F250 "Pulling Truck"
hhrecovery is offline
post #5 of 21 (permalink) Old 09-21-2009, 01:31 AM
harleystroker's Avatar
Send a message via Yahoo to harleystroker
looks great!!!
04 Harley F250 c/c s/b: 06 headlights, 3'' rough county lift, Eagle 20's, 35'' tarragrapplers, 4'' turbo back magnaflow with cat/muffler delete, 6000k HID's, Recon line of fire/ mirror lights/3rd brake/&Tales,Studs/gaskets,Tuned SCT X3,STL strobe kit, Icon shocks,Dfuser Egr/ Egr cooler delete, 03 turbo
http://i135.photobucket.com/albums/q...04/sq_com4.gif
harleystroker is offline
post #6 of 21 (permalink) Old 09-21-2009, 02:15 AM Thread Starter
BogginF350's Avatar
Aaron, the filter base utilizes a fl1995 motorcraft filter for the base engine filtration. 30% of that oil is then pushed through the 3 micron element. We did this to be a true bypass system. It will prevent the hpop and turbo from starving for oil in the event the 3 micron becomes plugged or restricted.
Josh Davis
6.0L Ford
6.4L Ford
(309) 699-2488
post #7 of 21 (permalink) Old 09-21-2009, 02:18 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
gotcha... in the one pic I thought that was 2 filters but in the other you can't see but 1 so I wasn't sure...
post #8 of 21 (permalink) Old 09-21-2009, 02:25 AM
abrannan19's Avatar
looks good, how much extra will it cost to get black fittings instead that red and blue *****?
what about the coolant bypass, when is that happening, I think I read something about it a year ago from you....
abrannan19 is offline
post #9 of 21 (permalink) Old 09-21-2009, 02:28 AM
Pappy
MOPSD250's Avatar
This on your website for sale yet?
2003 F250 Super Duty SC 8' Bed 12V CONVERSION DONE!!!!
24V P-pump Conversion Soon
MOPSD250 is offline
post #10 of 21 (permalink) Old 09-21-2009, 02:06 PM
strokin6L's Avatar
Josh the system looks awesome. Will there be an option for braided stainless line instead of rubber? Do you know what you will be charging for the system's yet? I've been planning on getting one, but have had a couple setbacks and hope to be getting one on the truck within the next few months.
strokin6L is offline
Bypass oil filtration John_DeereGreen 1994-2003 7.3L Power Stroke 28 06-26-2009 06:10 PM
LMM Oil Filtration Dirtbikindad393 Duramax 07.5-2010 (LMM) 5 02-26-2009 03:57 AM
Bypass filtration JPLTrucking 1994-2003 7.3L Power Stroke 2 01-17-2008 01:11 PM
Oil Filtration? tahoedmax Duramax 2001-2004 (LB7) 1 04-23-2007 02:44 PM
bypass oil filtration jdelongmotorsports 2003-2007 6.0L Power Stroke 5 08-29-2006 02:03 AM
