Fittings - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by DevilDocTater, this thread has received 8 replies and been viewed 681 times.
post #1 of 9 (permalink) Old 10-22-2009, 02:20 AM Thread Starter
Member Since Sept 2007
DevilDocTater's Avatar
Fittings
Im looking for the fitting i need so i can tap my intake elbow for my boost gauge. I think i need a 1/8NPT 90 degree elbow with a 1/8 inch compression fitting for the boost line??
Im also looking for an 1/8NPT tee fitting that fits into where your factory oil temp sending unit is so that i can run it and my oil temp gauge. I would think it would have to have 1 male and 2 female connections??
I would rather support the vendors here before i try Jegs or Summit
Any help would be greatly appreciated!!!
Thanks
Wade
"The best Battlefield Medicine is firepower superiority and overwhelming violence!"
SLAPS Member #193
Singles Club #212
3rd Degree Master Mason
2004 F-350 6.0 6" suspension lift sitting on 35's 6spd MANUAL 4" Turbo Back Exhaust, AFE Air Box, (ARP Studs, New HG's and Complete EGR Delete by Josh at River City Diesel) Coolant Filter from Dfuser, Stainless Steel Up-Pipe from RCD, 4 gauge pillar with Autometer Phantom Series 1 gauges. Boost, Pyro, Fuel Pressure and Oil Temp. Shimmed FPR. Improved Banjo Bolts. Fabtechs all around with a Procomp steering stabilizer from RCD. SCT X3 tuned by RCD
DevilDocTater is offline
post #2 of 9 (permalink) Old 10-22-2009, 02:24 AM
********* and Mafia #90
Bcarriveau's Avatar
Thanks
Wade
i take it my pm didn't go threw from my phone? its standard plumbing stuff you can get at, lowes, home depot, and or ace hardware.. Im sorry if i intrude on any sale but in reality it will end up costing more to ship the part then its worth just to buy
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 9 (permalink) Old 10-23-2009, 03:58 AM Thread Starter
I looked at both Home Depot and Lowes and they didnt have anything close. I went to the local commercial plumbing supply ans they are supposed to get back with me, the 90 degree elbow isnt hard to find, its the tee that seems to be eluding me.....
SLAPS Member #193
Singles Club #212
post #4 of 9 (permalink) Old 10-23-2009, 04:02 AM
Bcarriveau's Avatar
I think your over looking it..
this also shows shipping is more then the parts its self
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #5 of 9 (permalink) Old 10-23-2009, 04:11 AM Thread Starter
Amazon is the last place i would have looked........lol the places i have looked locally didnt have anything remotely close to that, and i like that fitting better because i comes with the plugs and i has an ectra port for when i later add my oil pressure gauge.
Thanks for the help bill, i envy people like you that can find stuff that quick.....
I owe you many beers!!!!
-Wade
SLAPS Member #193
Singles Club #212
post #6 of 9 (permalink) Old 10-23-2009, 04:16 AM
Bcarriveau's Avatar
in the styles box select tees...
http://www.anplumbing.com/shop/index.php
key with a T is not to make it heavy.. the "could" break if the metal is brittle.. had it happen on a civic i owned but it was also in the back of the block so the sender HUNG from it kinda pulling on it.
best bet is to run a small line from the port to the T, this way all vibration is dampened..
you should have no problem. im just rambling now
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #7 of 9 (permalink) Old 10-23-2009, 04:25 AM Thread Starter
Thats a good freakin idea!!!
Do me a favor and read the post from bgastrk in that thread i posted in 6.0 forum and tell me what you think
Thanks.....again
SLAPS Member #193
Singles Club #212
post #8 of 9 (permalink) Old 10-23-2009, 04:34 AM
Bcarriveau's Avatar
Thanks.....again
just replied to it.. Have a good night. i need some sleep
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #9 of 9 (permalink) Old 10-23-2009, 07:39 PM
BogginF350's Avatar
The oil temp sender uses straight thread o-ring boss fittings. Wade, you might be better off getting a oil filter cap that is pre threaded with the 1/8" npt that the sender would screw directly into. Or if you are serious about the oil bypass and relo you could also screw it into there.
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
AN Fittings dayusex Supporting Vendors Forum 0 10-03-2009 08:26 PM
Need (2) 90* fittings for heads Superstroker Supporting Vendors Forum 2 07-08-2009 04:25 AM
Big line fittings. kino_fab 5.9L Cummins (2003-2007.5) 1 01-23-2008 06:24 PM
Special fittings... Extended Power 2003-2007 6.0L Power Stroke 6 01-30-2007 03:21 PM
AN Fittings TC Dmax The Parking Lot 12 10-03-2005 01:07 AM
