NEW: 3 in 1 Combo Gauge - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Big Stroker, this thread has received 15 replies and been viewed 2740 times.
post #1 of 16 (permalink) Old 12-15-2009, 10:01 PM Thread Starter
These are a new Product out on the market. A 3 in 1 Combo Gauge that features - Boost, Exhaust Temp, Temp Readings.
Newly released 60mm 3 in 1 Combo Gauge allows you to easily monitor some of the most vital engine readings while allowing you to select from over ten back lighting colors designed to match your vehicle’s stock gauges. This unit will allow you to read boost pressure up to 60 PSI, exhaust temperature up to 2200 degrees Fahrenheit as well as a choice of oil, coolant or transmission temperature up to 300 degrees Fahrenheit. Boost pressure, exhaust and temperature sensors are all included. Select from ten bright back lighting colors as well as two color cycling modes including a color fade and color cycle feature. By bringing three meters into one gauge, this allows for a reduction in the amount of space needed for automotive gauges in your vehicle’s interior and at the same time allowing you to observe your engine more readily in one well designed compact unit. Install the included temperature sensor to either your oil, coolant or transmission senders to effortlessly monitor it using the digital temperature readout on the unit itself. Each package also includes a gauge pod to mount the unit on your dashboard.
•60mm black face gauge with magnified tinted lens
•10 color LED back lit illumination with color recall technology
•Digital readout
•Includes boost pressure, exhaust and temperature sensors(will work for trans, coolant, and oil temp)
SPECIAL PRICING - $150 per shipped
[CENTER]1995 PowerStroke 4x4 - 1968 Bronco
#27
Big Stroker is offline
post #2 of 16 (permalink) Old 12-15-2009, 10:29 PM
SSpeeDEMONSS's Avatar
wow, thats a pretty good deal. i wish i could come up with some money. 35psi and 1600* isnt enough.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 16 (permalink) Old 12-15-2009, 11:00 PM Thread Starter
Having all the functions in one are what makes them
#27
post #4 of 16 (permalink) Old 12-21-2009, 09:25 PM Thread Starter
I just got one of these in today. They are a VERY nice gauge. They come with EVERYTHING you need to install it.
#27
post #5 of 16 (permalink) Old 12-21-2009, 09:51 PM
JPscustoms's Avatar
just got mine today!!! very nice piece..cant wait to install
2005 f-250, 97 cummins and zf6spd!!!!
JPscustoms is offline
post #6 of 16 (permalink) Old 12-21-2009, 10:04 PM Thread Starter
COOL let us know what you think when you get it installed
#27
post #7 of 16 (permalink) Old 12-21-2009, 10:08 PM
JPscustoms's Avatar
will do hopefully will have time tomorrow!
post #8 of 16 (permalink) Old 12-22-2009, 07:19 AM
CSIPSD's Avatar
Who is the manufacture?
I like the idea...
CSIPSD is offline
post #9 of 16 (permalink) Old 12-22-2009, 04:27 PM Thread Starter
I like the idea...
Glowshift makes it
#27
post #10 of 16 (permalink) Old 12-22-2009, 05:44 PM
JPscustoms's Avatar
its quality piece, i pulled everything outa the box today! it should make for a very clean install...i wont get to install it till after new years prolly...
best combo martinrj 1994-2003 7.3L Chips & Tuners Forum 5 12-04-2007 05:21 PM
FYI for 6-speed/SCT combo SouthTexasDiese 2008-2010 6.4L Power Stroke 10 09-16-2007 06:29 PM
combo deals? rollin coal Supporting Vendors Forum 6 09-03-2007 04:49 AM
Am I looking at a +400 rwhp with this combo? jebsurf 1994-2003 7.3L Power Stroke 19 04-14-2007 03:27 AM
HYPERMAX combo pyro/boost gauge 6LTR4LIFE 2003-2007 6.0L Power Stroke 1 03-07-2007 01:31 AM
