Pure Performance 3.5" Suspension Systems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Skyd Ram, this thread has received 2 replies and been viewed 2768 times.
post #1 of 3 (permalink) Old 12-18-2009, 09:29 PM Thread Starter
Skyd Ram's Avatar
8LUG Truck Gear is proud to announce the new 3.5" Suspension Systems from:
Pure Performance has just upped the ante by introducing a couple of new 3.5" suspension systems for the 03-up Dodge Ram 2500/3500!
Starting at $899
Plus we have an introductory offer for Diesel Garage members(see bottom)
First up is the 3.5" X-Factor Kit
This is great system for running 35" tires and can be used a stepping stone to their Triple Threat kit.
System Includes:
(2) sport tuned coil springs
(2) adjustable front lower control arms made from 2" solid alloy steel
(2) adjustable billet aluminum sway bar end link assemblies
(1) track bar drop bracket made from 1/4" thick laser cut steel
(1) track bar cross brace kit
(1) tie rod flip kit
(2) high quality poly front bump stops
(2) 2" machined billet aluminum lift blocks
(4) u-bolts, hardware and detailed instructions.
Checkout all of the details on this system here:
Pure Performance 3.5" X Factor System
Next up is the 3.5" Triple Threat Suspension system.
This system builds on the X-Factor kit by adding upper control arms, dual rate coils and replacing the 2" block with a progressive mini-pack from Deaver.
System Includes:
(2) dual sport tuned front coil springs
(2) adjustable upper control arms made from 1 5/8" solid alloy steel
(1) track bar relocation bracket made from 1/4" thick laser cut steel
(1) track bar cross brace kit,
(2) billet aluminum double adjustable sway bar end links
(2) custom rear mini spring packs
(4) u-bolts, front poly bump stops, hardware and detailed instructions.
Checkout this systems details here:
Pure Performance 3.5" Triple Threat System
Both of these kits come without shocks so you can choose what you want to run. We suggest the Bilstein 5100's that are available on our website starting at $300 a set.
* We are offering these suspensions at an introductory rate of 20% off of MAP to Diesel Garage members until 12/31/2009. Just enter the coupon code "PURE20" after adding you system to the cart to calculate your special price. This discount will apply to the 3.5" systems as well as the 6" X-Factory short arm kit.
2010 CCSB Laramie Ram 2500 4x4
Powered By:
H&S/Shibby/Black Ops/Flo Pro
Suspended by:
Carli Suspension/Bilstein
2008 RCLB F250 XLT 6.4 Auto
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Pure Performance/Carli/Bilstein
Skyd Ram is offline
post #2 of 3 (permalink) Old 12-19-2009, 06:43 AM
Texas Member
crosstx's Avatar
the 4.5" triple threat for the superduty is awesome
how much are those?
i have seen them advertised for $1999
2008 F-250 Lariat CC/SB
NUTTY PROFESSOR KEM345, MBRP Duals (no dpf, cat,or muffler),
S&B Intake, RCD CAC, NXD 2 stage system, Bilstein 5100's, Pro-Comp trac bars, Banks intercooler, ARP studs, Suncoast tranny
ELITE: TOW Compound Turbos, EGR Delete, BOV, Wastegate, Nozzles, Ported Fuel Rails, ..
B.O.M.B Squad #29
#7
www.kemperformance.com
crosstx is offline
post #3 of 3 (permalink) Old 12-19-2009, 01:29 PM Thread Starter
Skyd Ram's Avatar
how much are those?
You are correct there sir!
It is a great value considering you get a 4-link conversion,Deaver progressive mini-packs, and some nice sway bar end links for under $2k. Just add a set of Bilstein 5100's and you are all set.
Although our current focus is the 03-up Dodge HD we also offer products for the Superduty from companies like Pure Performance,Carli Suspension,Icon Vehicle Dynamics,Bilstien,Rize.ProComp,BMF Wheels,Dynatrac,etc.
PM Sent on pricing.
Powered By:
Suspended by:
Powered By:
H&S/Flo Pro/aFE
Suspended by:
Skyd Ram is offline
Diesel Performance Systems Inc Exhaust. 1medic 2003-2007 6.0L Power Stroke 0 11-26-2009 05:33 AM
Free Shipping on Carli Suspension Systems Skyd Ram Supporting Vendors Forum 0 11-05-2009 05:29 PM
Pure Performance 8" Coil Over SFA Kit BombDocDiesel Supporting Vendors Forum 1 08-03-2009 11:41 PM
Suspension "shock absorber" on front end hopeful 6.0 General Ford Truck and Excursion 14 04-26-2007 07:22 PM
Pure Diesel Lizard Performance *must read* fordt The Parking Lot 56 10-28-2005 12:55 PM
