6.0L stock injectors w/bigger nozzles - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by HeavyAssault, this thread has received 3 replies and been viewed 1810 times.
post #1 of 4 (permalink) Old 01-13-2010, 10:27 PM Thread Starter
Pursuit Interceptor
HeavyAssault's Avatar
Images: 5
Question 6.0L stock injectors w/bigger nozzles
Anyone build such a toy for the 6.0L? PM pricing/options.
Officially The Biggest Midget In The Game
HeavyAssault is offline
post #2 of 4 (permalink) Old 01-13-2010, 10:35 PM
GOS
GOS's Avatar
Address your fuel system first and get a guage in it. Once you are good their you are ready for injectors. We've had alot of modified injector failures because of fuel supply issues. Once we get the fuel supply squared away we are good to go. How big do you want to go?
Contact 1-800-620-4467
Fax 1-406-222-4926
[email protected]
GOS is offline
post #3 of 4 (permalink) Old 01-13-2010, 10:42 PM Thread Starter
Pursuit Interceptor
Images: 5
I have an AD100 and larger lines to the front of the heads. Fuel pressure gauge to be installed soon. That setup is more than enough for simply adding larger nozzles. How large do the nozzles get?
post #4 of 4 (permalink) Old 01-13-2010, 11:08 PM
GOS
GOS's Avatar
I don't think your going to want to perform this by yourself. Problem is you have to pull injector apart and weld the return port shut. You've got to be very careful otherwise the plungers will stick. If you don't modify the injector internally the tip won't deliver more fuel. I should have read you first post more carefully. The Ford Injectors don't work like a Dodge Common Rail there are modifications that need to be made internally. If you injectors are good, you can send yours in and have them modified and have the tips installed. My bad sorry for the long post.
Fax 1-406-222-4926
[email protected]
GOS is offline
Bigger injectors on a stock truck yfz450_0569 5.9L Cummins (2003-2007.5) 28 08-17-2009 07:15 PM
Nozzles Vs Injectors Sabbath5.9 5.9L Cummins (2003-2007.5) 12 03-27-2008 08:38 AM
wanted lly injectors stock or 40% bigger fwdcummins Whats Been Sold 0 03-22-2008 11:00 AM
looking for 40% or bigger nozzles for lly fwdcummins Whats Been Sold 4 11-13-2007 02:28 PM
Bigger Turbo for Stock Injectors HotSauce2138 1994-2003 7.3L Power Stroke 34 01-12-2007 04:24 AM
