New White Face 3 in 1 Gauge - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Big Stroker, this thread has received 7 replies and been viewed 1585 times.
post #1 of 8 (permalink) Old 04-14-2010, 09:58 PM Thread Starter
White 3 in 1 Combo Gauge - Boost, Exhaust Temp, Temp Readings - PreOrder - Ships April 30th
GlowShifts newly released White Face 60mm 3 in 1 Combo Gauge allows you to easily monitor some of the most vital engine readings while allowing you to select from ten backlighting colors designed to match your vehicle’s stock gauges. This unit will allow you to read boost pressure from 0 to 60 PSI, exhaust temperature from 200 to 2200 degrees Fahrenheit as well as a choice of oil, coolant or transmission temperature from 68 to 302 degrees Fahrenheit. Boost pressure, exhaust and temperature sensors are all included. Select from ten bright backlighting colors as well as two color cycling modes including a color fade and color cycle feature. By bringing three meters into one gauge, this allows for a reduction in the amount of space needed for automotive gauges in your vehicle’s interior and at the same time allowing you to observe your engine more readily in one well designed compact unit. Install the included temperature sensor to either your oil, coolant or transmission senders to effortlessly monitor it using the digital temperature readout on the unit itself. Each package also includes a gauge pod to easily mount the unit on your dashboard. Each gauge includes GlowShifts standard one year limited warranty as well as free technical support.
Gauge Ranges:
Boost 0 to 60 PSI
Temperature 68 to 302 F
Exhaust Temperature 200 to 2200 F
Price: $169.99
[CENTER]1995 PowerStroke 4x4 - 1968 Bronco
#27
Big Stroker is offline
post #2 of 8 (permalink) Old 04-15-2010, 01:18 AM
JPscustoms's Avatar
have the black face one, works great!
2005 f-250, 97 cummins and zf6spd!!!!
JPscustoms is offline
post #3 of 8 (permalink) Old 04-15-2010, 07:21 AM
Trip's Avatar
I am thinking of getting one, do you have pics of install. thinking of mounting near the lie-o-meter above the center view, mirror would this work? I am starting to imagine lots of custom cutting of the headliner to accomplish this.
did I mention I am not a fan of needing to do home made custom work.
WALNUT (anti-ACORN) member#23
Trip is offline
post #4 of 8 (permalink) Old 04-15-2010, 04:32 PM Thread Starter
I think it would work I don't have any pics installed
#27
post #5 of 8 (permalink) Old 04-16-2010, 04:00 AM
DPDIESEL's Avatar
Looks pretty nice.
Performance Diesel Motorsports
5,500 RPM Common Rail Anyone??
DPDIESEL is offline
post #6 of 8 (permalink) Old 04-16-2010, 05:42 AM
Looks nice. Just went to their website and saw that they are actually a couple towns down the rd. Might have to stop by their and take a look tomorrow.
Thanks
03 f-350 cclb srw Oilguard bypass filter sct (doug and spartans tunes) boost,trans,pyro only problems 1 injector and a couple of reflashes runs flawless (knock on wood)
New Toy 97 dodge 2500 4x4 12 valve 4in turbo back exhaust and stock plate FF for now.
Mods to come in the near future
Built Trans, DV, 4k gsk, injectors??, studs
Fast_and_furious is offline
post #7 of 8 (permalink) Old 04-23-2010, 07:51 PM
97_redstroke's Avatar
I am happy to see someone doing a combination gauge like this I believe I will try one in the near future as well.
'97 F-250 HD ext. cab shortbox, 5" mitre cut stacks, edge evolution programmer, DIY intake.
97_redstroke is offline
post #8 of 8 (permalink) Old 04-23-2010, 09:46 PM Thread Starter
Let me know when your ready to try this gauge out you will love it
#27
Ford White or Dodge White Sabbath5.9 The Parking Lot 22 08-08-2009 01:51 AM
Ford White face gauges Tippy General Parts and Accessories 2 02-18-2008 11:29 PM
Anyone on face book ovruigo The Parking Lot 7 07-25-2007 01:07 AM
Evil Face djdieseltech Site Information 6 12-16-2005 05:20 AM
White Face Dash Guage Panels bigdraft General Ford Truck and Excursion 8 06-01-2005 04:56 AM
