Connecting Rod Release - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BogginF350, this thread has received 4 replies and been viewed 1018 times.
post #1 of 5 (permalink) Old 05-27-2010, 01:59 PM Thread Starter
BogginF350's Avatar
In the fall of 2008 we started drawings of the prototype connecting rod for the 6.0L Ford. We first started with a I beam design but later changed our minds to a H-Beam style to save reciprocating mass along with ease in the heat treat process. We then teamed up with R&R racing located up the road from us and put together this piece.
Water jet from Mil spec aircraft quality double re-melt E4340AQ chromoly steel. Similar to 300M Specifications Fully Machined Billet, Not Forged. Triple Tempered, Surface Peened, through hardened cryogenically treated and balanced +/- 1.0 Gram utilizing ARP fasteners. AMPCO 45 bushings, Magnaflux inspected and Rockwell tested.
These photos are from testing in March, 2010.
We are proud to say this is another part that will keep you running with the best!
Look for us on Facebook! Where we posted these photos back in March.
thanks again!
Josh Davis
Name:	6.0L Connecting rod.jpg
ID:	26113   Click image for larger version
Name:	6.0L Connecting rod 2.jpg
ID:	26114   Click image for larger version
Name:	6.0L Connecting rod 3.jpg
Josh Davis
6.0L Ford
6.4L Ford
WWW.RIVERCITYDIESEL.COM
(309) 699-2488
BogginF350 is offline
post #2 of 5 (permalink) Old 05-27-2010, 03:37 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
looks good... send me a set with some pistons and i can build this engine that is laying here... ..
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 5 (permalink) Old 05-27-2010, 04:29 PM
bigastrk's Avatar
What the going rate on a set of these?
03 6.0L Excursion < Sold
bigastrk is offline
post #4 of 5 (permalink) Old 05-28-2010, 05:37 PM
strokin6L's Avatar
looks like a very nice piece josh.
strokin6L is offline
post #5 of 5 (permalink) Old 06-03-2010, 08:14 PM
Steel's Avatar
cool!
2006 F350 CR/4R100 Fummins with Twins- 731HP 8-14-10--- Now with BIGGER TWINS
2009 Polaris Dragon 800 Race Gas Turbo- Winter Toy
"GOS Performance- Your Cummins Conversion Specialists"
800-620-4467
Check out our website here
GOS Performance Facebook
Steel is offline
Connecting Rods???? PPD PERFORMANCE 2003-2007 6.0L Power Stroke 12 05-16-2010 06:37 PM
Connecting an OBDII conn. to the 5.9 ISB kavemedic 5.9L Cummins (2003-2007.5) 1 08-02-2007 02:00 AM
Connecting Oil Pressure gauge BCFlyfisher 2003-2007 6.0L Power Stroke 3 03-22-2007 05:40 AM
Connecting Rod question your2slow Ford Oasis requests 2 03-06-2006 05:57 PM
Connecting Rods Metallakid 1994-2003 7.3L Power Stroke 3 08-03-2005 02:27 PM
