Reg-Return kits & fuel pumps - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bootcamp, this thread has received 10 replies and been viewed 1370 times.
Poll: Want setup are you running
Poll Options
post #1 of 11 (permalink) Old 01-16-2009, 12:19 AM Thread Starter
bootcamp's Avatar
Want to know how many are running the following set ups.
stock pump with regulated return kit
fass or airdog with regulatedreturn kit
fass or airdog without regulated return kit
55psi or 65 psi
not sure how or who sets up the poll
Thanks Paul
USMC 87-90 MOTOR-T
Build Date 01/05 05 F250 4x4 swb cc lariat
SCT XCAL3 Tune by DFuser,fluid damper,MBRP exhaust-no kitty, crossover fuel line, Coolant filter, CFM Intake elbow, Pro Comp 6" stage 2 lift and traction bars,ccv reroute, Gauges-trans,pyro,fuel,bbreg mod, B&W goose neck and companion hitch, firestone airbags, Earls anplumbing-6 hose and fittings to upgrade fuel lines,T/P stage I fuel line kit,Welded up pipe and welded egr cooler install, 4.10 yukon gears, ceramic coated manifolds install with new head gaskets and ARP's, PML trans pan, AEM brute air filter, AirDogII 165 sucking it straight off the bottom of the tank with Hellmans sump and Strictly Diesel RR kit
2010 Honda VFR1200 for when I really want to go FAST My newest collection to the armada, 2004 VW R32 and its all wheel drive
SINGLES CLUB MEMBER #259
bootcamp is offline
post #2 of 11 (permalink) Old 01-16-2009, 12:27 AM
SSpeeDEMONSS's Avatar
im running and Airdog FP-150 with my own non return fuel system at 65psi.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 11 (permalink) Old 01-16-2009, 12:41 AM
TDG Official Poo Flinger
TANK'S 250's Avatar
Images: 38
I'm running DJ's kit right now,...but I just bought this one,...I can't wait for it to get here.
Because they saw me on the internet,..they said anyone that comes from one of my truck sites, and says "TANK sent me",....will get a crazy deal on any of their kits.
http://www.trustedperformance.com/stageII.html
____________________________
Special thanks to:
TrustedPerformance.com
KLMperformance.com
Black Ops Bumpers
FarmboyFabrications.com
TANK'S 250 is offline
post #4 of 11 (permalink) Old 01-16-2009, 01:47 PM
TDG Mafia Member#67
6L strokin's Avatar
same setup as garrett...only return is the one coming out of the pump for fuel with air bubbles in it and fuel not needed....
Previous Rides:
1997 F150 EC SB 4x2 xlt red
6L strokin is offline
post #5 of 11 (permalink) Old 01-18-2009, 02:02 AM Thread Starter
bootcamp's Avatar
How do you set up the poll?
USMC 87-90 MOTOR-T
bootcamp is offline
post #6 of 11 (permalink) Old 01-18-2009, 08:06 AM
It may be too late for you to edit it. I think a super mod or admin has to add it.
2003 6.0 f250 ccsb 4x4 auto
Darsey715 is offline
The Following User Says Thank You to Darsey715 For this addition to TDG:
bootcamp (01-19-2009)
post #7 of 11 (permalink) Old 01-18-2009, 08:11 AM
********* and Mafia #90
Bcarriveau's Avatar
air dog fp150 no fuel return at all from motor(i want to get it there not take it away)
Added poll and voted
updated is as well
Garrett and Darin along with myself all have the same kits.
Tank is runnings djs return with a stock pump
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #8 of 11 (permalink) Old 01-19-2009, 06:48 PM
Diesel Dog's Avatar
I'm running two SD pumps in series at 75lb fuel preasure with reg. return
Off the shelf parts are good.
Diesel Dog is offline
post #9 of 11 (permalink) Old 01-20-2009, 01:47 AM
Bcarriveau's Avatar
that's a lot on HUEI injectors..
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #10 of 11 (permalink) Old 01-20-2009, 10:21 AM Thread Starter
bootcamp's Avatar
Thats different Diesel Dog, Could you really tell a difference on that 7.3?
USMC 87-90 MOTOR-T
bootcamp is offline
Regulated Return Kits......Again despain85 2003-2007 6.0L Power Stroke 16 04-25-2008 07:49 PM
E9 fuel pumps Mack Doctor Jr. Medium and Heavy Duty 1 02-22-2008 07:57 AM
hard starting IPs, fuel pumps and lift pumps jvbutter 7.3L and 6.9 IDI (Pre 1994) 5 11-08-2007 05:57 AM
7.3L Regulated Return Kits - FINALLY!!! Strictly Diesel Supporting Vendors Forum 0 08-04-2007 10:48 PM
Any Bad Fuel Pumps? cattech05 2003-2007 6.0L Power Stroke 2 02-16-2007 04:52 AM
