To oil or not? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by firehillbilly, this thread has received 16 replies and been viewed 1990 times.
View Poll Results: oiled filter or dry
oiled 13 48.15%
dry 8 29.63%
stock paper 6 22.22%
Voters: 27. This poll is closed
post #1 of 17 (permalink) Old 01-21-2009, 12:34 AM Thread Starter
resident mason
firehillbilly's Avatar
To oil or not?
Which is better oiled air filter or dry flow? I only get approx. 7k miles between cleanings and I'm tired of oiling mine.
06 Sierra 2500 4wd lb. Predator, S&B, MBRP duals-no cat, Quadzilla gauges, Allison Jr., Riderite air bags, PPE Tie rod sleeves, egr plate / finger stick. 02 Chevy 3500 8.1L 4wd dump 9' Fisher mm2, sander. 03 Kubota L4630. 80'S or 90's Komatsu pc50. 89 d250 5.9 which may someday go into something.:
firehillbilly is offline
post #2 of 17 (permalink) Old 01-21-2009, 02:14 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
I had both....... the dry filters break and tare easier............. and you get a better whistle out of the oiled ones anyways...
Jordan
blackcloudCTD95 is offline
The Following User Says Thank You to blackcloudCTD95 For this addition to TDG:
firehillbilly (01-21-2009)
post #3 of 17 (permalink) Old 01-21-2009, 02:15 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
They just get way dirty faster to me i oiled first now not one drop
Military Quote Of The Year
SOOTBANDIT is offline
The Following User Says Thank You to SOOTBANDIT For this addition to TDG:
post #4 of 17 (permalink) Old 01-21-2009, 04:10 AM
I personally prefer dry. I have heard too many problems with MAF sensors getting screwed up with oiled filters. The whistle from an filter should never be a deciding factor in what you use. Taking care of your engine is what should decide.
2005 Silverado 4X4 CC LB LLY
Air Lift Bags, Amsoil, KB IOH Kit, BD Manifold, Fumoto Valve, PCV Reroute, Resonator Plugged, Mag-Hytec Diff Cover & Trans Pan, PPE X STD, 4" SS Magnaflow Kitty Ran Off
MadJack Racing-Amsoil Diesel Specialist
Authorized FilterMag Dealer
Authorized Fumoto Dealer & April Special on Fumoto's Free shipping with entire kit.
Dirtbikindad393 is offline
The Following User Says Thank You to Dirtbikindad393 For this addition to TDG:
post #5 of 17 (permalink) Old 01-21-2009, 04:38 AM
I like beer.
NukleusX's Avatar
Send a message via AIM to NukleusX Send a message via Yahoo to NukleusX
wheres the option for no air filter at all? small birds in the intake = +15hp on average!
Jeremy
94 Ram 2500 4x4 RCLB.
Power: BHAF, 4" exhaust, S300G, 15.5*, 100 plate, 90 hp sticks, 191 dvs, Mike L. trans. more when i remember.
Appearance: 1 pc headlights, HIDs, 4.5" lift, flippy mirrors (up), not so chrome 6" silverline exhaust tip, not so fancy aftermarket wheels
American Club #33
Singles Club #74
TDG Mafia #111
http://www.socaldieseltrucks.com
NukleusX is offline
The Following User Says Thank You to NukleusX For this addition to TDG:
post #6 of 17 (permalink) Old 01-21-2009, 06:26 AM
Slow 6.0
ive always run K&Ns on my trucks, i have a total of over 100K miles using them and both trucks have immaculate compressor wheels which is a good indicator of how well your filter is actually filtering the air.
2006 F350 XLT 4x4
SICKS-O is offline
The Following User Says Thank You to SICKS-O For this addition to TDG:
post #7 of 17 (permalink) Old 01-21-2009, 06:44 AM
S-D Diesel Perf's Avatar
I like the pro guard 7 afe ,don't over oil it and with a outer wearer it works good.dry filter seem to let me down in silt and off roading.
03 F-250 FX4 10"Deaver Springs,4.30 Gears,Detroit Locker Rear,Pois In Dyna Trac Pro 60 Front,38"PJ's on 17"X12' Weld's,Cross over steering,Warn15,000lbs in Road armor Bumper, Engine:7.3 Bored 20 over,Mahle Coated Pistons & bearings,Crower Rods,WOP Main Girdle,Crower Valve Springs & Push Rods,Ported & Polished Heads,H-11's,Melling LPOP, Stealth Stage 2 HPOP,235cc Injectors With Edm/SHO Mods To Oil feeds By Gary/Cass,GTP38R,6.0 Spearco I/C All Cryo-ed,everything. DRUGS:Water & Meth Snow#2,Nos TUNEs by / ME
*Stealth Pumps*
The finest HPOP money can buy!
We have a new pony, we found him under that last pile of crap thread. He bite's , do you want to ride him? his name is Bittie !
S-D Diesel Perf is offline
The Following User Says Thank You to S-D Diesel Perf For this addition to TDG:
post #8 of 17 (permalink) Old 01-21-2009, 10:58 PM Thread Starter
resident mason
I'll probably keep my S&B and deal with it, but I do like the AFE with the bag. Seems good and simple.
post #9 of 17 (permalink) Old 01-22-2009, 02:22 AM
4cstr's Avatar
Images: 35
I've been told that some have lost boost with a dry filter.
~Dave~
4cstr is offline
The Following User Says Thank You to 4cstr For this addition to TDG:
firehillbilly (01-23-2009)
post #10 of 17 (permalink) Old 01-22-2009, 02:27 AM
I like beer.
NukleusX's Avatar
lost boost with a dry filter? that doesnt sound right to me...
what applications are you speaking of? any diesel? or a specific brand of motor?
i would not see where something that essentially makes the pores/openings in a filter smaller (oil) being something that improves airflow... then again im no engineer or scientist, so im open to hear this one...
Jeremy
American Club #33
Singles Club #74
TDG Mafia #111
NukleusX is offline
