07+ LMM Duramax - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4cstr, this thread has received 12 replies and been viewed 5692 times.
Closed Thread
post #1 of 13 (permalink) Old 07-03-2006, 02:21 AM Thread Starter
4cstr
07+ LMM Duramax
Rumor has it that GM will be coming out with a new version of the Duramax for 07...coded LMM. I've also read that the only difference between this engine and the LBZ might be the addition of a particulate filter.
If you have any further info...post it on up.
Dave
post #2 of 13 (permalink) Old 07-03-2006, 03:01 AM
Thanks Dave! Time to start shaking the trees for information!
TheBac is offline
post #3 of 13 (permalink) Old 07-03-2006, 03:04 AM
GOT BEER?
I bet the fuel mileage will increase now
Turbo life just decreased by 1/2
AKA dmaxfan
2011 F250 Lariat loaded
2010 F350 King Ranch Traded
2008 2500 Z71 GMC Black Crew Cab, PPE xcellerator
2006 LBZ 2500 4x4 GMC White Crew Cab, PPE xcellerator, 6" BDS lift, 18" procomp extreme alloy, 35/12.5/18 Toyo MTs
2004 LB7 4x4 GMC Sierra Sport Red Metallic- [email protected],500 miles
Ext. Cab Short Box
Predator Programmer MBRP 4" S.S. Exhaust
K&N Air intake & Bilsteins
ISSPRO Turbo & Exhaust gauges
Serial Fordicator is offline
post #4 of 13 (permalink) Old 07-03-2006, 08:15 AM
Procrastinator
Hopefully, if the rumor turns out to be true, you'll need to start a new section for the LMK 4.5L V8 diesels in the 1500s, Suburbans & Tahoes.
'06 GMC Sierra 2500HD LBZ/A CC/SB 4x4
Edge Beta
265Es on H2s
Pre R60s
'04 GMC Sierra 2500HD LB7/A EC/SB 4x4 w/134k miles sold
'00 Chevrolet Silverado 2500 6.0 EC/SB 4x4 w/237k miles sold
soot is offline
post #5 of 13 (permalink) Old 07-05-2006, 01:31 AM
zig
Don't know bout the engine for sure, been told the body style is definately changing. Supposed to look more like the Envoy! Don't know if that'll be good or bad though, have to wait & see!
zig is offline
post #6 of 13 (permalink) Old 07-05-2006, 01:48 AM
These are the only paragraphs I've seen about the new engine:
http://www.autoweek.com/apps/pbcs.dl...024/LATESTNEWS
I also found these GM docs dealing with the particulate filter:
http://www.gmfleet.com/gmfleetjsp/us...esel_Flyer.pdf
http://www.isuzucv.com/images/engine...ionsBro_GM.pdf
TheBac is offline
post #7 of 13 (permalink) Old 07-09-2006, 03:11 PM
i "heard" that the motor change is coming with the body change. the very first 07's will still look like the 06's, then the new body/motor
vern is offline
post #8 of 13 (permalink) Old 07-09-2006, 04:26 PM
Yep...I guess they're calling them "Classic". So I guess we all own "Old Body Style" trucks now.
LMM is supposed to show up around Jan 07 from what I've read.
TheBac is offline
post #9 of 13 (permalink) Old 07-10-2006, 10:26 PM
I worked with a person that was deeply involved in the motor. Here are a few things that were mentioned to me.
1. New rod and main bearing retaining bolts
2. New head gaskets (Its a riveted design)
3. Intake air valve (like a gas throttle body???)
4. Using one wild looking tailpipe called a jet pump
5. 5 pulse injection per power stroke
6. Particulate filter
7. Grid heater and glow plugs. The reason behind the 1000 watt grid heater is to keep the engine warm during low load like idle and to aid engine warm up
8. I was also told it watches the amount of soot and if soot levels are too high the egine turns the mil light on and causes a limp home mode. This will be the biggest challange to us hot rodders. Most likely all brands go to somthing like this and we will all have to deal with it eventually.
9. Last thing was that the engine is designed to run on ultra low sulfer.
Hope this helps give you guys a idea of what to expect!
BigRedISB is offline
post #10 of 13 (permalink) Old 07-11-2006, 02:32 PM
Guys,
One more thing I would like to add. The throttle valve I mentioned earlier is supposed to actually throttle air like a gasser. Why would a diesel need it? Gm's EGR is supposedly much more effective under a vacuum than a open air plenum. I have not seen it (the detailed shots of the throttle valve) yet but from the pics I saw she looks a lot more crowded on top of the engine with all the grid heaters and stuff.
Just wanted to provide a little more detail on the subject.
Closed Thread
