06 lbz - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cwalt, this thread has received 8 replies and been viewed 3371 times.
post #1 of 9 (permalink) Old 02-20-2011, 01:12 AM Thread Starter
Cummins Tower
Cwalt's Avatar
06 lbz
i just got a 06 lbz with 68000 miles on it is there any helpful things to know or watch out for?
-Cliff
"You know you wanna win the round, So when that brindle comes around, You better cok your hammer down, Don't quit till you head hits the ground, Go on and lift that leg and spur
You gotta get up in the neck, Step off and pick up your check" - Colby Yates
06 chevy silverado 2500hd duramax work done by dieseljunk.com!!
02 gmc sierra 2500hd duramax. if you only knew work done by dieseljunk.com!!
09 appalachian 24ft gooseneck trailer
Cwalt is offline
post #2 of 9 (permalink) Old 02-20-2011, 03:35 AM
battlegraduate09's Avatar
leaking tranny lines are a known problem, but that is an easy fix. LBZ is a great motor. No injector issues such as the lb7 and i havent seen a common issue of headgasket problems like the lb7 and llys have. Post up some pics and congrats on the new truck
04 LLY Duramax
battlegraduate09 is offline
post #3 of 9 (permalink) Old 02-20-2011, 02:06 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
Early 06's with the lly and early LBZ(trucks built in 05 and up to i think march) use the weaker designed gaskets, my truck had problems with this, and i have seen quite a few other 06's on other sites that have had this problem
they are an awesome truck, the engine is quiet, powerful, smooth, torquey and has fewer emissions than the 07.5+ NBS trucks
if you run too much injection timing with too much fuel you can drive cylinder pressures and temps through the roof and pistons can crack, but if you keep things pretty tame your should be good
the 6-speed is really nice too, good luck with the new rig and
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 9 (permalink) Old 02-21-2011, 01:26 AM
Pardue the Traveler
New 0mega's Avatar
Congrats on the new truck
Singles Club member #250
New 0mega is offline
post #5 of 9 (permalink) Old 02-24-2011, 01:25 AM
Not sure how common it is, but both power steering lines leaked on mine. Not bad, but they seeped and made them messy. You'll love the truck!
paoutdoorsman is offline
post #6 of 9 (permalink) Old 02-24-2011, 02:09 AM
TDG Mafia Goon
BombDocDiesel's Avatar
You need to watch out for people trying to buy it from you.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #7 of 9 (permalink) Old 02-24-2011, 03:19 AM Thread Starter
Cummins Tower
Cwalt's Avatar
yeah but everythings for sale for the right price
-Cliff
Cwalt is offline
post #8 of 9 (permalink) Old 03-20-2011, 02:34 AM
Cliff, if it is a 4 wheel drive, you'll want to pull the transfer case and install one of the pump upgrade kits to prevent the pump rub issue. These fail at random mileage from as low as 50K to some making it over 100K. The problem with watching for the failure, is that if you're on a trip you can push all your oil out and waste your transfer case before you realize you have an issue.
post #9 of 9 (permalink) Old 04-04-2011, 01:11 PM Thread Starter
Cummins Tower
Cwalt's Avatar
Yeah i'm gunna get one for it. i put one my 02 and it was easy to do
-Cliff
Cwalt is offline
