#4 glow plug - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by flyin05, this thread has received 4 replies and been viewed 6707 times.
post #1 of 5 (permalink) Old 12-14-2013, 03:33 PM Thread Starter
flyin05's Avatar
Send a message via AIM to flyin05
#4 glow plug
Hey guys, finally back with another diesel. I have a 2007 2500 lbz and it has thrown a code for the number 4 glow plug. I replaced what I thought was the number four (second back on drivers side) and I still get the code. I then decided to change out the second back on the passengers side. When I removed both glow plugs I ohmed them out and both were reading with resistance. My next question is where should I start to look? I still throw my code for the plug, is there any more common issues with the glow plugs or am I going to be tracing out wiring?
Thanks
Charlie
2009 trailblazer ss
Sold-2005 F250 4x4 ext cab. sct tuned bt DJ's, afe stage 2 intake, 58mm turbonetics turbo, cobalt series egt, boost, fuel pressure, 5in exhaust, head studs, egr complete delete by jpscustoms and myself
06022008-usmc
flyin05 is offline
post #2 of 5 (permalink) Old 12-15-2013, 05:09 PM
Pardue the Traveler
New 0mega's Avatar
which code is it? and did you check the wire going to the plug? have you checked the glow plug controller.
Singles Club member #250
New 0mega is offline
post #3 of 5 (permalink) Old 12-18-2013, 12:52 PM
rvn4me's Avatar
P0674
The last digit in the code indicates the cylinder number.
On the Dmax, the cylinders are numbered starting from the passenger front 1-3-5-7 and the driver's front 2-4-6-8.
First, disconnect the batteries. Some people don't.
Remove the inner fender liner which is the biggest PITA of the whole process. just that there are about 10 clips holding it in and it's got a couple of big harnesses clipped to it from inside also. You can get a good view of all 4 glow plugs this way- they're right on top of the exhaust manifold and slightly angled towards the back of the engine. There will be one wire with an 8 mm nut holding it on
Next, remove the 8 mm nut from the offending glow plug.
Next, using a 12 mm deep well socket, carefully remove the glow plug. Might need penetrating oil is probably a good idea. Some say warm the engine up helps.
They're supposed to have 1 ohm or less resistance.
Put some anti-sieze on the threads and started the new glow plug in the head by hand making sure not to cross the threads. Tighten to 18 ft/lb. Reinstall the connector and put the 8 mm nut back on the connector.
Put the fender liner back in, clear the codes and you're done.
07 Chevy Classic 2500 HD D/A CC/SB White
Bilstein shocks (yellow) Line-x. Good/Year Wrangler S/A 265/75/16 Nasta Nerf bars, Catch-all mats
rvn4me is offline
post #4 of 5 (permalink) Old 12-18-2013, 06:30 PM
All I would add to the list is, I turn the glow plug out a turn then use an air nozzle and blow away any dirt that may be present.
Also if the glow plug is within specs then you have to test the wire and controler.
I had #8 go bad, Now I have anouther one I wish I would have removed all the wires and tested the other three.
Just a thought!
Johnp3 is offline
post #5 of 5 (permalink) Old 01-04-2014, 11:30 PM Thread Starter
flyin05's Avatar
i got the plug all replaced but that didn't clear up the issue. how should i go about testing the controller, just to key it and make sure that it gets power going to the wire end? or is there a certain way to check it?
2009 trailblazer ss
06022008-usmc
flyin05 is offline
glow plug? vcassens 2003-2007 6.0L Power Stroke 4 12-28-2009 03:16 AM
Glow plug ? JakeDiesel 1994-2003 7.3L Power Stroke 9 01-21-2009 07:01 PM
Glow Plugs or Glow Plug Relay BillsFan 1994-2003 7.3L Power Stroke 6 12-18-2007 11:51 PM
problem checking glow plug with 5 pin plug Firefighter E2 1994-2003 7.3L Power Stroke 1 11-25-2007 06:18 PM
glow plug boatoo7 7.3L and 6.9 IDI (Pre 1994) 1 08-20-2007 03:13 AM
