07 d max gauge install , pyro and boost? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by joeseppy, this thread has received 3 replies and been viewed 2458 times.
post #1 of 4 (permalink) Old 06-06-2009, 06:43 PM Thread Starter
hey evryone,
was going to install a pyro guage and boost guage on my buddies 07 old style
deisel, and there used to be some pics on here on where to drill the manifolds etc, but cannot find them and the shortcut i had made doesn't work, anyone
here help me out with finding them?
thanks in advance
2002 f350 crew short,sct tuner(tunes by tad)econo , tow , and max power, afe stage 2 intake, mbrp 4 inch exhaust,285/75/16bfg at's,remote start,guages,2006 grill/harley headlamps,foil delete
joeseppy is offline
post #2 of 4 (permalink) Old 06-06-2009, 08:46 PM
I'm gonna put a new starter on tonight and I'll take a pic of the manifold for ya.
mckey73 is offline
post #3 of 4 (permalink) Old 06-08-2009, 01:37 AM
..thought I had some pics of when I installed mine..no luck...anyway..did some searching and finally found my source...
Here's the link
http://www.dieselplace.com/forum/sho...ht=hoot+method
Hopefully, the Mods will allow links to another website..? This is in fact excellent info and likely applicable to all of our diesels..not just GM's.
Nods to Hoot.!
Cheers,
Stk
Steakman is offline
post #4 of 4 (permalink) Old 06-08-2009, 06:19 AM
Sorry I took so long to reply.
I'm not sure if you can tap into the W/G actuator line on the lbz?? I "borrowed" the high temp pvc fittings from a friend.
This is on the passenger side manifold. When you drill and tap it keep the engine running and go slow. It won't get hot if it has been sitting for awhile. Wear glasses 'cuz the metal shavings will be blown in your face! When you run the tap in be careful not to go all the way in, you would like the pyro probe to be in the middle of the exhaust flow. It would be a good idea to test fit as you work the tap. I used the gold anti-seize stuff on the threads. If you have any questions PM me and I'll send you my phone #. The cable was run on the top of the firewall and then fed through by the pedals.
mckey73 is offline
boost gauge install AllOut0606 1994-2003 7.3L Power Stroke 20 03-09-2007 11:33 PM
HYPERMAX combo pyro/boost gauge 6LTR4LIFE 2003-2007 6.0L Power Stroke 1 03-07-2007 12:31 AM
boost and pyro gauge installation on 03 duramax andydale Duramax 2001-2004 (LB7) 3 09-29-2006 02:13 AM
please help pyro gauge install jaysvt Ford - Modification instructions, Product installs and Tech Articles 5 07-03-2006 07:26 PM
pyro gauge install (again) DiSTORTiON 2003-2007 6.0L Power Stroke 2 02-28-2006 01:44 PM
