2006 code p0087 help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by fordrambler, this thread has received 2 replies and been viewed 1984 times.
post #1 of 3 (permalink) Old 06-19-2009, 11:41 PM Thread Starter
checked out the neighbors truck,and if my code reader is right i have a p0087
"fuel rail pressure low". truck will lose power and might do 60 tops.
is this a comon problem? do the sensors go bad often or should i look somewhere else? help.
thanks
fordrambler is offline
post #2 of 3 (permalink) Old 06-20-2009, 02:36 AM
duramax9878's Avatar
semi comon does he have a tuner or pull alot of trailers
try a shim kit form ppe its like $10 and if the problem persists a lift pump should fix it
Danny
2006 LBZ Chevy with 4in. straight back Duals, K&N Intake, EFI Live V2, PPE Standard, BD Exhaust Manifold, Mickey Tompson Tires and Auto Meter Gauges, Tie Rod Sleeves, Pitman Arm Braces, N Fab Nerf Bars, Recon Smoked Cab Lights, Halo Projector Headlights, and more soon.
duramax9878 is offline
post #3 of 3 (permalink) Old 06-20-2009, 02:40 AM
the shim kit will stiffin the spring that allows to much fuel to be returned back to the tank the spring is just worn
that is just my idea for a fix
Danny
P0087???? forcefed6.4ford 2008-2010 6.4L Engine Tuner Forum 5 04-22-2009 09:08 PM
code p0087 low fuel pressure?? smokin in vt LBZ & LLY Tuner Forum 14 08-18-2007 12:49 AM
DTCs - P0087 amd P1093 Rooster49 Duramax 2004.5-2005(LLY) 2 02-12-2007 09:07 PM
Truck won't start giving a P0087 code NM Duramax Duramax 2001-2004 (LB7) 6 11-06-2006 02:36 PM
2006 calibration code location JohnJohn 2003-2007 6.0L Power Stroke 10 10-04-2005 09:52 PM
