'06 with power loss looking for answers... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Lark3po, this thread has received 14 replies and been viewed 10764 times.
post #1 of 15 (permalink) Old 05-27-2010, 02:02 AM Thread Starter
Diesel Noob
I have a 2006 CC 2500HD that seems to lost half its power. I had it programmed with my PPE standard at level 3 and noticed one day that my DMAX was a lot weaker then it was 2 months ago. I now get more black smoke then I remember getting too.
From zero to a third throttle it seems fine. If I go over a third throttle I get a ton of black smoke and little if any added power. Just more smoke. I took the level 3 off, went back stock and this thing is so weak I'm not even sure it'd pull a load much less pass a car.
After putting it back stock I got the following codes on the way home from work: P0101 and P0299. The air filter is maybe a year old. I cleaned the MAF sensor before going back stock with MAF cleaner. I do have the EGTs blocked and 4" (turbo back) exhaust on her. Not sure if either of those would throw those codes or not. The fuel filter still has 75% (per the DIC) life left on it. I did a quick once over on the intercooler boots and they looked fine.
The only thing other then the power that I've noticed about the truck is that the turbo doesn't seem to whistle as loud as it used to. I'm not sure if I'm getting used to it or if something is going wrong with it.
I would greatly appreciate any suggestions on what to look for or test so that I may get my power back.
-Lark3po
2006 Chevy Siverado K2500 HD CC SB
My 1st Diesel Truck - Used as Every Day Driver Not Currently Towing. Plan to get camper one day...
EGR Blocked | PPE Standard Level 3
MODS TO DO STATUS
___________________________
Transgo-jr................Done
Exhaust......................Done
Lift-Kit......................TO-DO
Anything else I should add to this list? TIA!
Lark3po is offline
post #2 of 15 (permalink) Old 05-27-2010, 06:10 PM
DrHolliday's Avatar
First 2 things I would look into are the airfilter and fuel filter. A year is a long time to have an air filter IMO.
Chris
2006 Chevy 2500HD LBZ/Allison ECSB 4x4 Greystone metallic
S475, 3" boost tubes, 5" intake, Custom Y-Bridge
Tuning and Transmission by Diesel Addiction . A special thanks to Dustin for all the help.
12.42 @ 106.3 (stock injectors, CP3, and turbo, no drugs!)
7.83 @ 86.2 1/8th
531 RWHP / 940 RWTQ 10/11/08 on Wayne's Dyno in Jville NC
USMC 2002-present
DrHolliday is offline
The Following User Says Thank You to DrHolliday For this addition to TDG:
Lark3po (05-27-2010)
post #3 of 15 (permalink) Old 05-27-2010, 06:57 PM Thread Starter
Diesel Noob
I agree. I'll replace both this weekend and see what happens. I appreciate the reply!
MODS TO DO STATUS
Lark3po is offline
post #4 of 15 (permalink) Old 05-27-2010, 09:08 PM
Gone Fishin...
merlin5577's Avatar
When you blocked the EGR did you disable the computer or install a finger stick?
+1 on the fuel filter, clogged filters can cause all kinds of troubles.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #5 of 15 (permalink) Old 05-27-2010, 10:57 PM Thread Starter
Diesel Noob
Well I went ahead and replaced the air filter tonight after work and boy am I glad I did!
Check out what I found:
Apparently a mouse had made a nest in my airbox. That gray fabric crap is from a vehicle cover I had over my '88 Chevy C1500. Looks like my truck shouldn't have even run it was clogged so bad. I think my engine was about ready to suck my air filter down and eat it for lunch.
MODS TO DO STATUS
Lark3po is offline
post #6 of 15 (permalink) Old 05-27-2010, 10:57 PM Thread Starter
Diesel Noob
Yeah, I blocked the code with my PPE. Thanks for the reply!
MODS TO DO STATUS
Lark3po is offline
post #7 of 15 (permalink) Old 05-27-2010, 11:07 PM Thread Starter
Diesel Noob
Is there any way to add "SOLVED" to this thread title on the main thread list?
MODS TO DO STATUS
Lark3po is offline
post #8 of 15 (permalink) Old 05-27-2010, 11:37 PM
Gone Fishin...
merlin5577's Avatar
WOW!!! I dont think I've ever seen a filter so clogged! Damn lucky the truck even ran, congrats on fixing the problem though.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #9 of 15 (permalink) Old 05-28-2010, 03:50 AM
ADMIN/MAFIA
neeltburn's Avatar
Man, That is crazy! But hey you got your money's worth out of it!
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #10 of 15 (permalink) Old 05-28-2010, 06:30 PM
Pardue the Traveler
New 0mega's Avatar
good thing you didn't suck any of that into your turbo.
Singles Club member #250
New 0mega is offline
loss of power wskeith 1994-2003 7.3L Power Stroke 4 11-02-2007 02:41 AM
power loss? paulkeith 1994-2003 7.3L Power Stroke 5 08-04-2007 03:16 PM
Loss of power imported_06F450 2003-2007 6.0L Power Stroke 8 08-04-2007 03:42 AM
Loss Of Power 1997 6.5L TD 6.5L Diesel Engine 1 05-06-2007 02:31 PM
7.3 loss of power Robts 1994-2003 7.3L Power Stroke 2 10-29-2006 05:18 AM
