engine dies randomly - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by peanut, this thread has received 2 replies and been viewed 1554 times.
post #1 of 3 (permalink) Old 06-30-2010, 03:25 AM Thread Starter
I got an edge juice on an 03 lb7, and randomly on hot days (over110) the display will go black and the engine will die, Wait ten seconds and try to start it and it'll fire up but sometimes the display wont read any of the parameters I have it set to monitor, its done this about six times and like I said it has to be hot outside for it to happen, any ideas? also where can I find tie rod sleeves?
03 GMC Sierra ext cab/sb 4x4, air raid intake, magnaflow exhaust, edge juice with attitude, rhino lined bed, leveled
peanut is offline
post #2 of 3 (permalink) Old 06-30-2010, 05:42 PM
Gone Fishin...
merlin5577's Avatar
Take the Edge off and see if the symptoms persist. For Tie-Rod Sleeves, check out the vendos section.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #3 of 3 (permalink) Old 07-20-2010, 09:48 PM
The edge doesn't like heat, so make sure your unit isn't near anything hot in your engine compartment. Try to put it close to an area where fresh are is coming in. As for sleeves, I would suggest Merchant automotive.
03 Chevy Silverado 2500 HD, K/N intake, PPE boost fooler, Edge hot juice w/monitor, 4" MBRP turbo back exhaust, Line X bed lining, B/W turnover hitch, Merchant Automotive xfer case pump upgrade
Dux2bux is offline
6.5 randomly cutting off wytepirate 6.5L Diesel Engine 9 02-20-2009 12:32 AM
Engine dies, have to prime fuel filter to get it to start??? Dmax05 Duramax 2004.5-2005(LLY) 3 03-05-2008 02:44 AM
6.5 Engine dies when turning/ GM Diagnoses wirenuts 6.5L Diesel Engine 7 04-09-2007 07:00 PM
wastegate comes open randomly. help! jroderick 2003-2007 6.0L Power Stroke 10 04-29-2006 12:51 AM
