Need some help truck dying - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Cummins02, this thread has received 2 replies and been viewed 997 times.
post #1 of 3 (permalink) Old 07-24-2010, 11:29 PM Thread Starter
my dad just bought a 02 duramax with the 6 spd manual. it also has a juice with attitude. when you are driving at any given time the truck will die, the tach will start jumping, and the battery light flashes in the message center. once you pull over to the side of the road, the truck will start back fine as nothing happened. can anyone help us with this problem? thanks
Cummins02 is offline
post #2 of 3 (permalink) Old 07-25-2010, 03:50 AM
That guy
thefermanator's Avatar
Start by removing the EDGE and monitor and see if it still happens. Been ALOT of problems with EDGE's stuff causing stalling and no starts.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
post #3 of 3 (permalink) Old 07-29-2010, 02:06 AM
When u find out let me know too..... Mine did it before I ever put the edge system on and it does it once every 10K miles. Mine seems to die right after I have let up on the accelerator like going up a hill then getting to the top or getting on it to pass someone then get in front of the person and it dies. Usually just throw it in neutral and hit the key and fires right up and don't miss a beat and keep on rolling. No codes at all. Little gremlin running around.
03 Chevy Silverado 2500 HD, K/N intake, PPE boost fooler, Edge hot juice w/monitor, 4" MBRP turbo back exhaust, Line X bed lining, B/W turnover hitch, Merchant Automotive xfer case pump upgrade
Dux2bux is offline
need help my dog is dying AUSSIEDAVE The Parking Lot 40 03-24-2010 05:44 AM
I think my transmission is dying.. HELP!! Stroker01 1994-2003 7.3L Power Stroke 10 02-18-2010 03:14 AM
The dying priest bmoeller The Parking Lot 0 12-07-2009 12:29 PM
Truck keeps dying! Fast_Ashley 1994-2003 7.3L Power Stroke 5 02-05-2007 03:16 AM
OT - Dog dying... John_G The Parking Lot 25 08-13-2006 04:46 PM
