fuel problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cwood22, this thread has received 4 replies and been viewed 861 times.
post #1 of 5 (permalink) Old 07-26-2010, 12:51 AM Thread Starter
fuel problem
I have 2003 with 160000 miles and when i put the pedal to the floor it feels like it runs out of fuel and shuts off. I took it to the dealer and they said it was the fuel filter housing does this sound correct? I am wondering because i cant see any leak
05 White and Tan F 250 lariat with a leveling kit, 33 12.50 20 nitto mud grapplers, 20 inch black moto metal 951s, innovative tuned sct, 4 inch straigt pipe, afe stage two intake, 5 percent tint, pioner head unit, and a infinity perfect 12 powered by a 900 watt arc audio amp.
cwood22 is offline
post #2 of 5 (permalink) Old 07-26-2010, 01:13 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
More than likely its a problem of air leaking into the fuel system rather than fuel leaking out
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 5 (permalink) Old 07-26-2010, 01:18 AM Thread Starter
So where is the best place to find a housing
cwood22 is offline
post #4 of 5 (permalink) Old 07-26-2010, 03:11 AM
CRAZY CANUCK
are you 100% positive that it is the fuel filter housing? have you changed the fuel filter lately? the bleed screw is made of plastic and can easily crack or become damaged if you over tighten it, also if you dont get the filter properly seated and tightened it will cause air intrusion as well
Ridin Dirty Club #5
TDG TOTQ
post #5 of 5 (permalink) Old 07-28-2010, 03:41 AM Thread Starter
i really dont see anywhere it could be leaking from and i have made 100 percent sure the filter is seated right. I guess its just somewhere on the housing? I dont know anything else it could be
cwood22 is offline
Fuel Problem BigRed6.7CTD 6.7L Cummins (2007.5-2011) 2 07-09-2010 03:57 AM
fuel problem? BigRed6.7CTD 6.7L Cummins (2007.5-2011) 5 06-30-2009 01:06 PM
fuel problem????? topflight250 1994-2003 7.3L Power Stroke 1 05-25-2009 03:05 AM
fuel problem with 97 f-350 josh 1994-2003 7.3L Power Stroke 9 05-23-2007 06:41 PM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 03:35 PM
