What year was the Allison Introduced? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by kevinsilverado, this thread has received 5 replies and been viewed 1489 times.
post #1 of 6 (permalink) Old 07-29-2010, 06:28 PM Thread Starter
Need For Speed
kevinsilverado's Avatar
Has GM been using the Allison since 2001? Just been curious.
kevinsilverado is offline
post #2 of 6 (permalink) Old 07-30-2010, 04:21 AM
That guy
thefermanator's Avatar
Yes, it came out for the 01 model year for the DURAMAX and 8.1L in the 2500HD and 3500 trucks. I believe it came out before then though in the medium duty trucks.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
post #3 of 6 (permalink) Old 08-03-2010, 04:36 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
The ALLISON 1000 has been around for a while, but first made its way into the gm hd trucks in 2001 as fermanator stated, its too bad we couldn't stuff an allison 2000 into our trucks, the could handle more torque that's for sure
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 6 (permalink) Old 08-09-2010, 03:52 AM
That guy
The 1000-2400 all use the same frictions, they just have different gearing, parking brake or not, or parking pawl. The 3000 series is HUGE in comparison though to the 1000/2000 series.
The Following User Says Thank You to thefermanator For this addition to TDG:
BriteWhiteRam (08-09-2010)
post #5 of 6 (permalink) Old 08-14-2010, 04:30 PM
do the allison 1000 and 2000 both have the same mounting locations cause it would be cool if someone put a 2000 behind a dmax
sportsmandiesel17 is offline
post #6 of 6 (permalink) Old 08-15-2010, 04:16 PM
CRAZY CANUCK
from what i understand the 2000 wouldn't be a big improvement over the 1000, very similar components, you either need to build your 1000, or buy a 3000..... either choice is gona hurt the wallet
Ridin Dirty Club #5
TDG TOTQ
When was egr introduced to cummins 6litrefan 5.9L Cummins (2003-2007.5) 19 07-23-2014 05:35 AM
Help My Allison might be BAD!!! zgoo Medium and Heavy Duty 9 02-15-2010 03:42 AM
allison 545 help 90suburban 5.9L Cummins 12 Valve (1994-1998.5) 10 06-15-2009 06:16 PM
2wd Allison to 4wd.. ToddPSD GM Transmissions 2 03-26-2009 01:16 AM
Allison Jr. firehillbilly GM Transmissions 7 02-12-2008 02:51 AM
