Duramax Diesel Quit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 2001Diesel, this thread has received 8 replies and been viewed 2577 times.
post #1 of 9 (permalink) Old 08-03-2010, 03:18 AM Thread Starter
Duramax Diesel Quit
I acquired a 2001 GMC Sierra Duramax 3500 from a family member. Ran fine for close to 3000 miles (has 50K on odometer). The engine started ran for 20 seconds and shut off. Cranks fine, won't start. Fuel delivery?
2001Diesel is offline
post #2 of 9 (permalink) Old 08-03-2010, 03:41 AM
That guy
thefermanator's Avatar
Most likely an air leak. Have you tried pumping the fuel primer yet? Chances are either the filter is bad, the o-ring around the primer base is bad, or the fuel lines at the front of the engine have cracked. The DMAX fuel system runs under vacuum, so any air leak will shut her right down.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
The Following User Says Thank You to thefermanator For this addition to TDG:
2001Diesel (08-04-2010)
post #3 of 9 (permalink) Old 08-03-2010, 03:44 AM Thread Starter
New to diesels, how do I pump the fuel primer??
post #4 of 9 (permalink) Old 08-03-2010, 04:18 AM Thread Starter
Pumped primer 8 to 9 times, achieved pressure, still won't start. Primer did leak fuel on my hand, primer leak???
post #5 of 9 (permalink) Old 08-03-2010, 04:31 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
Did you losen the plastic screw beside the primer first? That screw has a tendancy to break or strip and can cause an air leak as well
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
post #6 of 9 (permalink) Old 08-04-2010, 01:56 AM Thread Starter
Smile
Thanks for the insight. I replaced the fuel filter purge screw and primed the system. Engine runs. Sad the the whole system can be disabled by a plastic screw.
post #7 of 9 (permalink) Old 08-25-2010, 07:40 PM
Supporting Vendor
NickMA's Avatar
A leak at the stock plastic bleeder screw is fairly common. We offer an Aluminum Bleeder Screw to help avoid that problem.
Nick Beaudoin
Merchant Automotive
http://www.merchant-automotive.com/
866-399-7169
[email protected]
NickMA is offline
post #8 of 9 (permalink) Old 08-25-2010, 07:40 PM
Supporting Vendor
NickMA's Avatar
NickMA is offline
post #9 of 9 (permalink) Old 09-04-2010, 12:47 AM
Toyaholic
a good investment
01 Chevy CC/SB 4WD. Not Quite Stock.
vrabel is offline
LML Duramax Diesel vs 6.7L Power Stroke Diesel Jeremiah 2011+ 6.7L Power Stroke Diesel 61 07-14-2010 02:28 PM
Bio-Diesel in the Duramax cowhorse Bio-Diesel/ULSD/Additives Discussions 7 03-02-2010 02:00 AM
03 duramax quit again dirtrider Duramax 2001-2004 (LB7) 1 05-05-2008 10:43 AM
1st Diesel purchase Duramax vs Powerstroke 5. Slow General Diesel 10 03-20-2008 04:29 AM
Chevy Diesel/Duramax Clubs wideopen General GM Truck Forum 7 06-15-2005 03:43 PM
