Understanding cyl Balance fuel flow rate - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Sledpuller500, this thread has received 2 replies and been viewed 1599 times.
post #1 of 3 (permalink) Old 08-23-2010, 10:30 PM Thread Starter
Inline Junky!
Sledpuller500's Avatar
Images: 121
I need a little help here. I got a 2001 With a nasty knocking sound that comes and goes. Sounds like a pre-det knock but im not sure so i was doing some reading here and there during work today and figured id do a balance test.
So here are the results
------avg -----high
cyl1 __-4.51__ -4.11
cyl2 __-0.09__ 0.19
cyl3 __-2.49__ -2.06
cyl4 __-3.49__ -3.95
cyl5 __3.05___ 3.47
cyl6 __0.04___ 0.55
cyl7 __0.91___ 1.38
cyl8__ 7.10 __ 7.34
Is this telling number 1 and 8 are the problems? from what i could read +/- 4 is ok
I also did a cyl drop test and no change in tone of knock
Sledpuller500 is offline
post #2 of 3 (permalink) Old 08-24-2010, 12:38 AM
Administrator
fordt's Avatar
Images: 5
Oh boy....that's not good!
-Wayne
2007 Chevy LBZ 6.6L Classic
fordt is offline
post #3 of 3 (permalink) Old 08-24-2010, 12:38 AM
That guy
thefermanator's Avatar
I would say she is due for all 8 as 1,3,4,5, and 8 are out there. The spec is +/- 4 in park and +/- 6 in gear, but these are the figures that GM came out with to cut down on warranty work. I've found much more than +/- 2.5 to cause smoking and other issues.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
Injector Flow Rate (Liters Per Minute) adambomb 2003-2007 6.0L Power Stroke 3 09-18-2009 03:21 AM
stock fuel pump flow rate JPscustoms 2003-2007 6.0L Power Stroke 19 04-22-2009 04:27 AM
LMM 07 Fuel Injector Flow Rate Programming ripmf666 GM Spec Info 0 12-28-2008 10:18 AM
LBZ 06 Fuel Injector Flow Rate Programming ripmf666 GM Spec Info 0 12-28-2008 10:11 AM
turn up fuel rate in a 6.2 4cstr Chevy - Modification instructions, Product installs and Tech Articles 3 04-13-2008 06:53 AM
