Turbo ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Q'sDMAX, this thread has received 2 replies and been viewed 1039 times.
post #1 of 3 (permalink) Old 09-30-2010, 02:07 PM Thread Starter
Turbo ?
Can you put a variable geometery turbo on a LB7?
Q'sDMAX is offline
post #2 of 3 (permalink) Old 09-30-2010, 07:05 PM
That guy
thefermanator's Avatar
Yes it is possible to put a late model variable turbo on an LB7, but why is the real question? IIRC it involves swapping in the correct up-pipes and base for the turbo to mount to. Then you have to either run a homemade wastegate controller to control boost which would work similiar to your current wastegate set-up, or run a FLEECE controller to run the servo for the VVT mechanism(I for one wouldn't run a FLEECE product again after my experience with them).
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
post #3 of 3 (permalink) Old 10-05-2010, 02:13 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
agreed, a turbo with a larger inducer wheel, and smaller exhaust housing will give more flow with better spooling characteristics over the stocker
Im pretty sure PPE has a turbo vane controller as well... but dont quote me on that
the cost of setting up a VVT is going to be a whole lot steeper than getting a bigger turbo
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
Isspro Turbo monitor or Turbo timer proud1 1994-2003 7.3L Power Stroke 4 03-11-2010 11:46 PM
7.3 turbo wanted for 1991 pre turbo rwbmaine Whats Been Sold 0 05-24-2009 10:45 PM
1991 Ford 7.3 Non Turbo I Need To Figure Out How To Turbo It blacksmokeobs 7.3L and 6.9 IDI (Pre 1994) 7 04-01-2009 12:51 AM
Wanted: Early 99 PSD Turbo Pedistal with or without turbo. WyoDieselCowboy Whats Been Sold 3 04-22-2007 09:20 PM
Very oily tube post turbo. Means Bad turbo seals? I10HaulR 2003-2007 6.0L Power Stroke 1 03-07-2007 10:59 PM
