Power problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wlpatterson, this thread has received 4 replies and been viewed 1077 times.
post #1 of 5 (permalink) Old 10-02-2010, 12:14 PM Thread Starter
Unhappy Power problem
I have a 2001 4dr I ton GmC Duramax that loses power.I recently made a 500 mile trip & it lost power & wouldnt exceed 60mph.If you accelerate it would just bog down,infact it was hard to get going because it took so long to get it fast enough to shift.I have had the filter changed 4 times in the last 12 months & it helps for a little while & back to no power..Also if I prime the fuel filter it will work for a short distance..The first couple primes it feels like it has air in it.(mushy) Im almost postive its an air issue but this just started out of the blue??Any help, suggestion or reccomendations you can provide will be greatly appreciated..Again,Thank you...
wlpatterson is offline
post #2 of 5 (permalink) Old 10-03-2010, 04:54 PM
That guy
thefermanator's Avatar
Any codes present? Are the fuel lines up on the engine origanal?
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
post #3 of 5 (permalink) Old 10-04-2010, 12:51 AM Thread Starter
2001 duramax
The fuel lines are the original,I actuall havent had a scanner on it yet..I will do that this week--
post #4 of 5 (permalink) Old 10-05-2010, 02:16 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
i would guess your getting air as well, but most air issues will cause the truck to die.....
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #5 of 5 (permalink) Old 10-08-2010, 11:02 PM
jdreda's Avatar
my 03 did the same thing no pwr foot to the floor especislly with a small trailer on it. Found it was the injection pump replaced it now doing 80 with a 10,000 lb trailer on it.
jdreda is offline
odd no power problem GruntTorque 2008-2010 6.4L Power Stroke 5 03-29-2010 10:31 PM
Sprinter Van power problem sasafrass77301 Euro-Diesels 1 06-08-2009 04:14 PM
power problem hay hauler 1994-2003 7.3L Power Stroke 4 03-17-2008 05:25 AM
Power steering Problem woodduck31 1994-2003 7.3L Power Stroke 2 08-22-2007 09:47 PM
Need help power problem bmxdirtjumper13 1994-2003 7.3L Power Stroke 1 06-23-2007 05:51 PM
