2002 duramax puffing smoke from exhaust and oil filler cap - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bridre, this thread has received 4 replies and been viewed 7872 times.
post #1 of 5 (permalink) Old 10-25-2010, 04:32 PM Thread Starter
I have a new problem. I have only recently noticed that my truck is smoking from the exhaust at idle and acceleration, and it also blows smoke out of the oil filler cap, enough so, that it will blow the cap of once it has been unscrewed. The smoke is a bluish/grey/purple from the exhaust, and the oil in the motor has been changed several times and is very clean. The oil level seems to stay steady. At first, I figured bad injectors, then pcv valve(but then discovered there were none), so now, I wonder, is it rings, fuel filter(never changed by myself yet). I have changed the oil, oil filter, air filter, and that's it. GM said they changed the injectors, but who really knows? Any ideas on what this problem may be? Any help will be appreciated. I'd like to know what I may be up against here. Thanks
bridre is offline
post #2 of 5 (permalink) Old 10-25-2010, 05:10 PM Thread Starter
Just called another GM service department, they said that the injectors have never been changed by them, and that there are no recalls for my vehicle, ecept for the door cable. Could it be the injectors????
bridre is offline
post #3 of 5 (permalink) Old 10-26-2010, 02:59 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
what does the exhaust smell like? is it really sweet like diesel fuel? or does it smell like regular diesel exhaust?
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 5 (permalink) Old 10-26-2010, 04:30 AM Thread Starter
It smells like regular exhaust, but this is the first diesel I've owned. Usualy, there is only a faint bit of exhaust smoke while the engine is cold, but after driving for a while, it gets darker, and more noticable, to the point where people give me the finger. It seems to be at idle and acceleration only, but maybe I just can't see it once the truck is moving and the wind gets the smoke away. My main concern is the crank case pressure coming from the oil filler cap, because on all gas engines I've ever owned, this is BAD news, and always means a new engine.
bridre is offline
post #5 of 5 (permalink) Old 10-29-2010, 05:06 AM
CRAZY CANUCK
got me on this one bud, never heard of crank case pressure on these things before
Ridin Dirty Club #5
TDG TOTQ
Tags
crankcase pressure, exhaust smoke, oil filler, smoke
Big Cam Puffing white smoke LOG HAULER Medium and Heavy Duty 4 10-04-2010 01:47 PM
2002 Duramax SC 2wd ToddPSD Whats Been Sold 7 02-15-2008 06:24 PM
puffing white smoke dangerous196 General Dodge Discussion 0 12-05-2007 07:36 PM
no start 2002 duramax ash_flat_diesel Duramax 2001-2004 (LB7) 0 05-11-2007 12:36 AM
2002 Duramax rattle ssnarski Duramax 2001-2004 (LB7) 8 03-19-2006 05:52 PM
