Stuck in limp mode - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 06F450, this thread has received 12 replies and been viewed 19321 times.
post #1 of 13 (permalink) Old 11-09-2010, 04:14 AM Thread Starter
Dually Club Member #96
06F450's Avatar
Stuck in limp mode
I have a 2002 2500hd D-Max/Ally with banks 6 gun loader, and 37's. tuner is almost always on stock or 1. Was getting off the freeway and came to a stop and went to take off and lots of rpm and very little mph, then the cel came on. codes P0700 and P0756 show. Ive tried also to shut it down and restart, after resetting the cel. This this a common issue?
2006 F450
SCT X3 Tuner (with EGR Off), A.R.P. Studs, AiRaid Drop In Filter, AutoMeter Pyro, Zoodad Mod, CCV Reroute, Hollowed & Piped Kitty, 4" Kitty Back Blown Coal in Front Of Rear Wheel, F550 Brakes, Splicer Rear End W/ 4:30 Gears, High Idle Mod, 12'x8' Harbor Contractor Combo Bed, More To Come After Economy Picks up. 13k All Day... Everyday
WARRANTY WORK :
(2) Altenators, (2) Batteries, (6) Sensors, (1) Turbo, (1) Full Engine Harness, (1) E.G.R. Cooler, (3) E.G.R. Valves, (1) I.C.P. Sensor... Hopefully thats it??? UPDATE10,2010; All Dummy Plug Seals, 2 fuel injectors, ECM, Both Silicon Boost Hoses, Clean Turbo... im sure theres more to come
7-2011 E.G.R. Cooler, Oil Cooler, Gaskets, Clamp, Filters, Fluid, Other BS... $1000 Work Done In Garage.
11-2-2011 Head Gaskets, degas bottle with cap, ring for turbo, egr cooler, temp sending sensor, radiator, thermostat, ficm, glowplug module, fluids, filters, and other gaskets... Material, tax, labor at dealer... $5900
A.R.P. studs... $466
11-15-11; Egr valve, and crank position sensor
06F450 is offline
post #2 of 13 (permalink) Old 11-10-2010, 12:44 AM Thread Starter
06F450's Avatar
Or any idea of the extent this might be? gGoing to change the solenoid this weekend, if any ideas before this weekend please let me know. Thanks
2006 F450
WARRANTY WORK :
06F450 is offline
post #3 of 13 (permalink) Old 11-10-2010, 01:29 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
Looks like your in for a rebuild, p0700 is tcm requested mil, and p0756 is 2-3 shift solenoid, no gears
I may be off base but usually when you limp the allison its time for a rebuild, check your fluid for burnt smell, brown flakes, and just remove the spin-on filter and check the magnet for metal shavings
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 13 (permalink) Old 11-11-2010, 03:38 AM Thread Starter
06F450's Avatar
Thats not good news. But the fluid is clean, (dip stick film). My book says P0756 is solenoid b, performance or stuck off. this that right? I was under the impression this tranny only has two solenoids, labeled as "a", and "b". i do have the ally 2000.
2006 F450
WARRANTY WORK :
06F450 is offline
post #5 of 13 (permalink) Old 11-11-2010, 04:07 AM
TDG Mafia Goon
BombDocDiesel's Avatar
2500HD with LB7 will have an Allison 1000. How many miles are on the truck? A 6 Gun with SL on stock tires can eat an Allison. It can kill it pretty quickly trying to spin 37s if you rod it at all. Remember, the 5 speed isn't as stout as most people think.
Actually you have 5 solenoids; Trims A & B as well as Shifts C, D, E & F.
The fluid can be just fine. That means the filter and screen are working. Pull the spin-on and check the magnet. Make sure you have a fresh filter. You need to use a large tubing cutter and cut the filter top off and look at the trappings. Also be aware the shavings and burnt clutch material will sit at the bottom of the pan most of the time and all of the time if the truck isn't running.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #6 of 13 (permalink) Old 11-12-2010, 02:03 AM Thread Starter
06F450's Avatar
ok i'll do that, damb it, all nervous now. Cant afford to brebuild.
2006 F450
WARRANTY WORK :
06F450 is offline
post #7 of 13 (permalink) Old 11-12-2010, 03:53 AM
TDG Mafia Goon
Let us know what you find. When you pull the spin-on, dump the fluid through a white paper towel and see how it stains. A lot of dark brown means a lot of clutch material. When you look inside if there is a lot of brown in there you can guess what it means. If your magnet has a lot of the metal on it you will most likely see a lot of clutch material.
Either way, this only costs $17 to know for sure.
Since the P0700 has been cued, you may want to try to reset by disconnecting the batteries for a few minutes. I don't remember how many it takes. That should clear the MIL from the TCM.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #8 of 13 (permalink) Old 11-13-2010, 03:36 AM Thread Starter
06F450's Avatar
Ya i ran the scanner thru and cleared the codes, then drove the truck, after about 1/2 mile if went into limp again. I will share what i find. Hoping sunday I'll have time. I'll disconnect the batteries, and try it one more time for *****s and giggles, before i open anything up. I'll post sunday eitherway.
2006 F450
WARRANTY WORK :
06F450 is offline
post #9 of 13 (permalink) Old 11-15-2010, 05:01 AM
Pardue the Traveler
New 0mega's Avatar
So what did you find?
Singles Club member #250
New 0mega is offline
post #10 of 13 (permalink) Old 11-20-2010, 03:55 AM Thread Starter
06F450's Avatar
Man, work picked up and working 12hr days leaves no time for the truck... I will post when I look.
2006 F450
WARRANTY WORK :
06F450 is offline
2004 LLY in limp mode dirtrider Duramax 2004.5-2005(LLY) 9 12-19-2010 11:09 AM
How to Clear Limp Mode? Lindy02GMC GM Transmissions 2 10-02-2007 10:26 PM
Limp Mode!!!!!!!!!! powersmoke18 2003-2007 6.0L Power Stroke 17 08-31-2007 03:57 PM
limp mode? f350bart 2003-2007 6.0L Power Stroke 5 05-19-2007 03:13 AM
06 in limp mode Smokin 5.9 Duramax 2006-2007(LBZ & LLY) 3 02-12-2007 10:21 PM
