Rough idle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Smokd2dmax, this thread has received 6 replies and been viewed 1988 times.
post #1 of 7 (permalink) Old 11-10-2010, 07:16 PM Thread Starter
Diesel Enthusiast
Rough idle
Okay so I just installed my air dog 150 and after a series of test drives I have noted that when I take my foot off the pedal after acceleration or normal driving, it tends to idle rough...Anybody else's truck doing this?
Smokd2dmax is offline
post #2 of 7 (permalink) Old 11-23-2010, 11:04 PM
Supporting Vendor
NickMA's Avatar
I've seen it caused by having too much pressure at the fuel filter..... I'd get with Airdog, or whoever you bought it from and see what the pressure there is supposed to be and see if it's a relief valve issue.
Nick Beaudoin
Merchant Automotive
http://www.merchant-automotive.com/
866-399-7169
[email protected]
NickMA is offline
post #3 of 7 (permalink) Old 11-24-2010, 12:37 AM
MAFIA #8
hhrecovery's Avatar
Images: 1
did you recieve the correct airdog2 for a dmax and not something else????
2003 F250 "Pulling Truck"
hhrecovery is offline
post #4 of 7 (permalink) Old 12-07-2010, 11:55 PM
if its got a rough idle then it shouldn't matter wheter its to much pressure because there is return line to the tank. try running some lucas cleaner in the fuel system. my truck did that when i put the fass fuel system on myne and i got aggervated about it so i changed my filter under the hood and added lucas fuel system cleaner and it will eat out the wax residue built up in the injectors and fuel rails.
01Woods89 is offline
post #5 of 7 (permalink) Old 12-08-2010, 03:55 AM
That guy
thefermanator's Avatar
Too much pressure to the CP3 at idle on a DURAMAX WILL cause a nasty lopey idle as the regulator is adjusted in the ECM to control the fuel pressure with a vacuum to the pump. Normally you want to stay under about 10-12 at idle if possible to maintain a decent idle, but 7-8 is better.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
The Following User Says Thank You to thefermanator For this addition to TDG:
merlin5577 (12-08-2010)
post #6 of 7 (permalink) Old 12-08-2010, 01:21 PM Thread Starter
Diesel Enthusiast
Does anyone know how to adjust the pressure on the air dog?
post #7 of 7 (permalink) Old 12-08-2010, 02:18 PM
Gone Fishin...
merlin5577's Avatar
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
05 rough idle fishnut LLY Overheating Discussions and Solutions 3 10-25-2009 05:29 PM
another weird idle ?, rough idle oh3_6oh 2003-2007 6.0L Power Stroke 3 01-09-2008 04:48 AM
Rough Idle MattyB4x4 2003-2007 6.0L Power Stroke 1 10-17-2006 12:25 AM
rough idle fordfanatic69 2003-2007 6.0L Power Stroke 1 07-28-2006 03:25 AM
Rough idle 6.0? QtrHorse 2003-2007 6.0L Power Stroke 7 09-16-2005 02:29 AM
