Trans question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by OffKilter, this thread has received 7 replies and been viewed 1489 times.
post #1 of 8 (permalink) Old 11-29-2010, 08:57 PM Thread Starter
Truck pullin' S.O.B.
OffKilter's Avatar
Images: 13
Trans question
Posting this for a friend. He has an 03 2500 duramx/allison with 145000 miles and it has an Edge juice box under the hood thats all for mods. Every so offen when he puts it in reverse it won't go anywhere and the message center on the dash says Range Select Inop or something like that and he has to shut the truck off and restart it then it might work fine. And also where the gear selector display doesn't light up at all ever. Would that have something to do with it not shifting? I have never worked on a Chevy and this is his first diesel.
1999 F-250 Lariat, Red, Super Cab, Short Box, 6.8L V-10
2003 F-350 XLT Regular Cab Long Box 6.0L 6-speed, tinted windows, push bar, 4inch MBRP exhaust, Edge Juice w/ attatude.
1969 F350 "The Shillelagh" future pulling truck, 428ci, 4-speed, 4:10 gears.
OffKilter is offline
post #2 of 8 (permalink) Old 11-30-2010, 04:02 AM
That guy
thefermanator's Avatar
Sounds like the NSBU switch is going out on him. It is a semi common problem on these trucks and will cause it to not go into gear, gear display won't read, and it will display range shift inhibited. It is the switch that is on the gear selectro shaft that goes into the trans. Also don't buy the switch from GM, but find an ALLISON dealer to get it from. It will be the same switch for half the cost. Just give them the serial number off the trans and they can look it up for you as 03 can be either the early 2 plug or the late single plug style.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
The Following 2 Users Say Thank You to thefermanator For this addition to TDG:
BriteWhiteRam (11-30-2010), OffKilter (11-30-2010)
post #3 of 8 (permalink) Old 11-30-2010, 04:28 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
had no idea what to call it, thanks Fermanator
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 8 (permalink) Old 12-07-2010, 01:35 PM Thread Starter
OffKilter's Avatar
Images: 13
ok we changed the NSBU and I fixed a wire that was about to break. The truck was fine for about a day or so but he said it still does it and the gear selector still isn't lit up. any other ideas?
post #5 of 8 (permalink) Old 12-07-2010, 11:59 PM
change your filters there is one inside that you'll have to drop the pan and change the spin on. when you change the spin on there should be a magnet at the top of the threads where it spins on. you want that magnet dont lose it. change the tranny fluid and go with synthetic fluid.
01Woods89 is offline
post #6 of 8 (permalink) Old 12-08-2010, 01:42 AM
CRAZY CANUCK
changing the fluid wont fix his problem
not sure bud...
Ridin Dirty Club #5
TDG TOTQ
post #7 of 8 (permalink) Old 12-08-2010, 01:49 AM
Gone Fishin...
merlin5577's Avatar
Allison states not to change the internal filter unless the transmission is being rebuilt. Only change the external one.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #8 of 8 (permalink) Old 12-08-2010, 05:42 PM Thread Starter
OffKilter's Avatar
Images: 13
I don't see what a filter change is going to do it seems like a electrical problem to me.
trans question Sabbath5.9 5.9L Cummins (1998.5-2002) 7 05-07-2009 02:58 AM
Trans Question rsjohnsn 2003-2007 6.0L Power Stroke 2 02-08-2008 01:06 AM
Trans. question firecat 2003-2007 6.0L Power Stroke 4 05-05-2007 09:56 PM
'96 12v trans question CTDNewbie 5.9L Cummins 12 Valve (1994-1998.5) 5 04-08-2007 05:10 AM
yet another trans question goldenfox 2003-2007 6.0L Power Stroke 1 06-23-2006 01:26 AM
