3/4 ton rearend..I need some help!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by [email protected], this thread has received 1 replies and been viewed 1012 times.
post #1 of 2 (permalink) Old 11-30-2010, 06:33 PM Thread Starter
Question 3/4 ton rearend..I need some help!!
My rear end has the factory limited slip..14bolt full floating..Ipulled the ring gear and carrier out..now how do you get the spider gears out?..there are two little bars that engage the limited slip..the ring that actuates the diff lock is broken a 24$ part..to buy aftermarket carrier is 600$ @ 4wheel parts.i need to know how to remove the spider gears
post #2 of 2 (permalink) Old 12-01-2010, 04:44 PM Thread Starter
no worries took it to the local shop for rebuild
05 350/450 rearend JPscustoms 2003-2007 6.0L Power Stroke 26 12-30-2009 07:37 PM
Rearend? Nick Albert 5.9L Cummins 12 Valve (1994-1998.5) 6 08-10-2009 02:34 PM
how much rearend fluid? FordRacing200 1994-2003 7.3L Power Stroke 4 09-09-2007 03:24 AM
rearend MOOSE 04 Drag Racing 0 05-15-2007 03:48 AM
08 SD rearend what is it ?? onebadf150 2008-2010 6.4L Power Stroke 11 10-01-2006 01:19 PM
