Time for glow plug set # 3 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by merlin5577, this thread has received 8 replies and been viewed 1609 times.
post #1 of 9 (permalink) Old 12-07-2010, 03:32 AM Thread Starter
Gone Fishin...
merlin5577's Avatar
Stupid check engine light is back on. Got a dead glow plug in cylinder # 8. Back to the dealership for another set. Looks like 60K is about all thats to be squeezed out of them.
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #2 of 9 (permalink) Old 12-07-2010, 04:26 AM
That guy
thefermanator's Avatar
Cali emissions system does seem to go through some glow plugs. Mine had 162K on it when I did the swap, and only 1 was bad.
1995 GMC 2500 SUBURBAN, DURAMAX/ALLISON, 3.42 gears, 261 T-case, Trans has a mild build with ALOT of help from MIKE L. which included ALTO's for C1-C4, PI ML converter, DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, EFILIVE, KENNEDY single pump, pump rub kit
http://www.thetruckstop.us/forum/showthread.php?t=10142
thefermanator is offline
post #3 of 9 (permalink) Old 12-07-2010, 04:44 AM
Pardue the Traveler
New 0mega's Avatar
Is it the same glow plug that dies?
Singles Club member #250
New 0mega is offline
post #4 of 9 (permalink) Old 12-07-2010, 02:13 PM Thread Starter
Gone Fishin...
merlin5577's Avatar
Not the same one, the same ones. Last time started the same way. #8 cylinder dies, then # 7 will go. Then #'s 1 & 2. Seems to be the 'outer' four take some exta abuse.
Either way, the dealership will (should) replace all 8.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #5 of 9 (permalink) Old 12-07-2010, 02:15 PM Thread Starter
Gone Fishin...
merlin5577's Avatar
Any thoughts as to why? Right now I'm still under warranty, but eventually these will come out of my pocket, so if there is a 'fix', i'd like to know. Thanks!
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #6 of 9 (permalink) Old 12-07-2010, 04:00 PM
That guy
EFILIVE and reduce your glow plug times would work. The CALI emissions runs the glow plugs for quite awhile after the engine starts which puts alot of stress and heat to the glow plugs. With EFILIVE you can reduce the glow plug on time and reduce the amount of heat they go through. Or you can get an ECM from a federal emissions truck and swap glow plug controllers and elimintae the EGR at the same time.
The Following User Says Thank You to thefermanator For this addition to TDG:
merlin5577 (12-07-2010)
post #7 of 9 (permalink) Old 12-07-2010, 09:12 PM Thread Starter
Gone Fishin...
merlin5577's Avatar
That makes sense, the longer they are on, the shorter the life span.
Wouldnt that trip a CEL as I have a catalytic converter and PCV too?
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #8 of 9 (permalink) Old 12-08-2010, 03:56 AM
That guy
Basically you would be converting it to a federal emissions truck and do away with the cat. The downside is if you have emssions inspections.
post #9 of 9 (permalink) Old 12-08-2010, 04:02 AM Thread Starter
Gone Fishin...
merlin5577's Avatar
That would be a problem. MA does emission inspections.
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
glow plug? vcassens 2003-2007 6.0L Power Stroke 4 12-28-2009 03:16 AM
Glow plug ? JakeDiesel 1994-2003 7.3L Power Stroke 9 01-21-2009 07:01 PM
Glow Plugs or Glow Plug Relay BillsFan 1994-2003 7.3L Power Stroke 6 12-18-2007 11:51 PM
problem checking glow plug with 5 pin plug Firefighter E2 1994-2003 7.3L Power Stroke 1 11-25-2007 06:18 PM
glow plug boatoo7 7.3L and 6.9 IDI (Pre 1994) 1 08-20-2007 03:13 AM
