Block heater ... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dux5977, this thread has received 4 replies and been viewed 949 times.
post #1 of 5 (permalink) Old 12-28-2010, 06:09 PM Thread Starter
Block heater ...
I had the bright idea of having my block heater <BH> install on the driver side ..make a long story short. Mech removed the old BH and i waited n waited finally i said the heck with it and called another place to install. They informed me that <after calling dealer> that LB7 arent required to have BH installed. I live in Michigan and not feeling to good about not having one. I was quoted a price in the $500 range, because they would have to remove an engine mount then lift it alil to get it in. Now will not having a BH cause problems in the long run? sits outside in the weather
2004 LB7 stock w/allison trans
dux5977 is offline
post #2 of 5 (permalink) Old 12-28-2010, 06:22 PM
Could you use a "Tank Type" heater in the heater hose?
gloesch is offline
post #3 of 5 (permalink) Old 12-28-2010, 07:19 PM Thread Starter
im not sure ...
well would this be the best way? or would a oil pan heater be better?
dux5977 is offline
post #4 of 5 (permalink) Old 12-28-2010, 09:52 PM
I am not sure that a Tank heater would be the best but it would be a option. The main thing is to remember to mount the tank lower than the hose so it has a constant coolant supply. These will also move coolant through the system. Can get at a TSC store, NAPA, ETC.
gloesch is offline
post #5 of 5 (permalink) Old 12-30-2010, 05:38 AM
Pardue the Traveler
New 0mega's Avatar
I don't know why the dealer would say that, LB7 sold here have a block heater installed. The block heater should go in the passenger side. From Gm, a block heater for my 2007.5 is $700cdn, the block heater cord on the passenger side is intertwined with the starter cable, so its all sold as one unit.
Singles Club member #250
New 0mega is offline
Block heater Stacked6600 1994-2003 7.3L Power Stroke 12 02-27-2010 06:18 PM
6.0 block heater littlebigrig6.0 2003-2007 6.0L Power Stroke 29 12-16-2009 06:01 PM
block heater and magnetic oil pan heater DZL BULL 2003-2007 6.0L Power Stroke 3 12-14-2009 01:20 PM
Block heater 97cummins 5.9L Cummins 12 Valve (1994-1998.5) 6 01-18-2008 03:25 AM
block heater on 06 FSTDZL 5.9L Cummins (2003-2007.5) 10 02-21-2006 05:02 PM
