2001 duramax 6.6 4x4 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by willtrade2004, this thread has received 2 replies and been viewed 1447 times.
post #1 of 3 (permalink) Old 01-08-2011, 05:41 AM Thread Starter
Lightbulb 2001 duramax 6.6 4x4
this truck is a buddy of mine and they went to work ran out fine went to leave and wouldnt start they used eather and it fired but then died so ok so no fuel i get that they had the injection pump changed a year ago if u pump up the primer it gets hard then after a while it bleeds off about 2 mins and pump it up and turned it over and no fire no smoke new to diesel work so any answers would be great
willtrade2004 is offline
post #2 of 3 (permalink) Old 01-08-2011, 05:50 AM
TDG Mafia Goon
BombDocDiesel's Avatar
I wouldn't use ether again.
If you are just pumping the primer pump and not turning the bleeder it should firm almost instantly. The pressure will back down, though.
If it's already had a new CP3 I would guess something else in the fuel system isn't working.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #3 of 3 (permalink) Old 01-10-2011, 03:11 AM
Pardue the Traveler
New 0mega's Avatar
Could be a cracked fuel line/bleed screw letting air into the system. For sure don't use ether again.
Singles Club member #250
New 0mega is offline
Tags
duramax diesel
2001 Duramax DTC's Marty Duramax 2001-2004 (LB7) 3 03-23-2007 05:41 AM
2001 duramax dually 4x4,flatbed huffkid Whats Been Sold 1 01-26-2007 02:25 PM
2001 duramax 200,000 should i buy heavypulling Duramax 2001-2004 (LB7) 3 01-16-2007 02:31 AM
Limp Mode 2001 Duramax gasco Duramax 2001-2004 (LB7) 12 12-06-2006 08:50 PM
2001 duramax Robts Duramax 2001-2004 (LB7) 3 03-18-2006 02:24 AM
