Sensor or Fuel problem? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Shelpster, this thread has received 3 replies and been viewed 1239 times.
post #1 of 4 (permalink) Old 02-06-2011, 12:23 AM Thread Starter
My truck started acting like it was running out of fuel, I changed the filter, ran great for one day, back to the running out of fuel,(when I changed the filter it was not completely full of fuel when I took it out of the truck)and when I changed the filter the water sepertor that screws into the bottom of the filter, felt funny like it want to strip the threads out, so I changed the filter and the seperator ran good for about 2 hours, now it is running worse than it was before, I let it sit for about 5 hours, I did nothing to it, starts up and runs good for about an hour then runs poorly again, my question is, can it only be sucking air sometimes? Do I have an electricial problem? Please help this is driving me crazy
Thank you,
Shelpster
Shelpster is offline
post #2 of 4 (permalink) Old 02-06-2011, 03:24 AM
Try running with the fuel cap loose.Sounds like cap is not venting.
hdgeorge is offline
post #3 of 4 (permalink) Old 02-06-2011, 08:43 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
Thank you,
Shelpster
Have you looked at the threads on the WIF sensor? if it felt like it was stripped then it could be sucking air there
fuel cap? i dont think that would cause this but who knows, it sounds like an air leak in the fuel system to me
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 4 (permalink) Old 02-09-2011, 03:30 AM
As these engines don't have a fuel transfer pump, if the fuel tank doesn't vent properly it will create a vacuum and starve for fuel and stall.
hdgeorge is offline
Problem with sensor on the master cylinder DIESEL73 1994-2003 7.3L Power Stroke 3 03-16-2010 02:41 AM
MAP Sensor problem? Aaronchev72 5.9L Cummins (1998.5-2002) 5 10-30-2009 12:09 PM
vt 365 sensor problem kilalove21 Medium and Heavy Duty 2 07-28-2009 12:22 PM
Cat 3116e: Fuel Temp Sensor & Boost Pressure Sensor probablecause Medium and Heavy Duty 0 02-03-2009 01:54 AM
Problem!! Cam Positioin Sensor?? dotson90 1994-2003 7.3L Power Stroke 11 08-16-2007 06:36 PM
