Leaking transmission lines - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Dux2bux, this thread has received 3 replies and been viewed 5744 times.
post #1 of 4 (permalink) Old 02-22-2011, 01:19 PM Thread Starter
My transmission cooling lines are leaking at the crimps, does anyone have line on where to get replacements? I have called local parts stores with no luck. Thank you for any info.
03 Chevy Silverado 2500 HD, K/N intake, PPE boost fooler, Edge hot juice w/monitor, 4" MBRP turbo back exhaust, Line X bed lining, B/W turnover hitch, Merchant Automotive xfer case pump upgrade
Dux2bux is offline
post #2 of 4 (permalink) Old 02-23-2011, 07:03 PM
Pardue the Traveler
New 0mega's Avatar
You can check ebay, you can also check online. If there is a local Hydraulics shop, if you bring in the old lines they could make you up a set.
Singles Club member #250
New 0mega is offline
The Following User Says Thank You to New 0mega For this addition to TDG:
Dux2bux (03-01-2011)
post #3 of 4 (permalink) Old 02-26-2011, 03:21 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
http://cgi.ebay.ca/chevy-silverado-d...QQcmdZViewItem
this is the kit I have, braided high pressure hydraulic line, better fittings and crimps
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following 2 Users Say Thank You to BriteWhiteRam For this addition to TDG:
Dux2bux (03-01-2011), New 0mega (02-28-2011)
post #4 of 4 (permalink) Old 05-05-2011, 01:38 PM
Supporting Vendor
NickMA's Avatar
We offer a repair kit for the stock leaking lines.
http://www.merchant-automotive.com/t...it-lb7lly.aspx
Nick Beaudoin
Merchant Automotive
866-399-7169
[email protected]
NickMA is offline
The Following 2 Users Say Thank You to NickMA For this addition to TDG:
BriteWhiteRam (05-06-2011), New 0mega (05-09-2011)
Leaking GM Trans Lines...there is a fix. Steakman GM Transmissions 18 11-16-2010 02:55 AM
Allison lines leaking???? hlhinc2000 GM Transmissions 11 02-26-2009 11:03 AM
tranny lines leaking Cozy Homes D-MAX GM Transmissions 1 02-18-2009 02:19 PM
Leaking Automatic Transmission Cooler Lines 91rangerturbo 5.9L Cummins (1998.5-2002) 3 01-21-2009 10:48 PM
HPOP lines leaking? 91redstang 1994-2003 7.3L Power Stroke 1 04-26-2007 01:33 AM
