engine manual - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dfmax, this thread has received 4 replies and been viewed 1296 times.
post #1 of 5 (permalink) Old 02-22-2011, 10:49 PM Thread Starter
engine manual
Does anyone know where to buy a GOOD dmax engine overhaul manual?
dfmax is offline
post #2 of 5 (permalink) Old 02-23-2011, 12:26 AM
Cummins Tower
Cwalt's Avatar
best place is helmsinc.com i think the site is
-Cliff
"You know you wanna win the round, So when that brindle comes around, You better cok your hammer down, Don't quit till you head hits the ground, Go on and lift that leg and spur
You gotta get up in the neck, Step off and pick up your check" - Colby Yates
06 chevy silverado 2500hd duramax work done by dieseljunk.com!!
02 gmc sierra 2500hd duramax. if you only knew work done by dieseljunk.com!!
09 appalachian 24ft gooseneck trailer
Cwalt is offline
post #3 of 5 (permalink) Old 02-23-2011, 12:53 AM Thread Starter
engine manual
Thanks but I own a set of the service manuals from them. They do not have the duramax engine, allison transmission or anything about the LT interiors. Other than that they are pretty good. Helped me out on a tranfer case teardown.
dfmax is offline
post #4 of 5 (permalink) Old 06-30-2011, 04:30 PM
have you tried to find at Haynes or eBay?
randyfredric is offline
post #5 of 5 (permalink) Old 07-09-2011, 10:42 PM
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
Most of the info you will need is posted here. http://www.duramaxdiesels.com/forum/...splay.php?f=97
I started a area here also but need to work on it some if you do not see what your looking for I can add it.
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/[email protected]:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline
#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced ripmf666 GM TSB Info 0 08-10-2009 04:46 AM
switching from a manual 5 speed to a manual 6 speed BEHR2010 1994-2003 7.3L Power Stroke 13 04-25-2009 03:27 PM
Few questions about engine swap: Manual to automatic transmission.. Lunchbox 7.3L and 6.9 IDI (Pre 1994) 2 04-20-2008 02:49 PM
manual starting engine =( dodgedisorder 5.9L Cummins 12 Valve (1994-1998.5) 9 08-23-2007 04:20 AM
Possible to measure engine deck specs on engine in truck? Trulyvintage 7.3L and 6.9 IDI (Pre 1994) 3 06-16-2007 04:10 AM
