04 dmax - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SOOTBANDIT, this thread has received 1 replies and been viewed 1165 times.
post #1 of 2 (permalink) Old 04-29-2011, 02:35 AM Thread Starter
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
04 dmax
Ok need a little help boys servicing the tranny on these trucks it has 180k i was told a external filter and synthetic fluid??? Or do i need to do a external filter and tranny flush and then synthetic fluid??? She going under the knife tomorrow morning. Thanks
Military Quote Of The Year
SOOTBANDIT is offline
post #2 of 2 (permalink) Old 04-29-2011, 01:44 PM
CRAZY CANUCK
BriteWhiteRam's Avatar
taking the filter off does not drain the fluid, you need to remove the drain plug on the bottom of the pan, and when you remove the spin on filter you need to make sure to keep the magnetic washer on the top of the filter and replace it on the new filter
Allison recommends 'Trans-Synd' synthetic ATF as their #1 replacement oil
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
SOOTBANDIT (05-06-2011)
6.0 vs Dmax imported_DieselKid Road Kill, Bench Racing 42 02-21-2008 08:11 AM
dmax help? imported_diesel71 Duramax 2006-2007(LBZ & LLY) 0 08-10-2007 12:22 AM
Dmax vs 6.0!!!!! DmaxRig Road Kill, Bench Racing 2203 06-26-2007 03:07 PM
New to dmax McDiesel Duramax 2001-2004 (LB7) 6 05-27-2007 06:10 PM
New best in an 05 LLY Dmax bobo Drag Racing 20 06-10-2006 04:06 AM
