Dropping fuel tank! Needs some up grades! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by auto83s, this thread has received 12 replies and been viewed 5760 times.
post #1 of 13 (permalink) Old 05-04-2011, 01:46 AM Thread Starter
I have an 03 lb7 with 218000 and going strong. My sending unit went bad and my fuel gauge is on E and won't move. So I thought I would ask while I have the fuel tank down what else can I do under there? After market fuel pump? I'm open to all ideas. Someone please steer me in the right direction!
auto83s is offline
post #2 of 13 (permalink) Old 05-04-2011, 03:00 AM
ADMIN/MAFIA
neeltburn's Avatar
First off, I would pull the bed, this is what I did when I installed my AirDog... How much fuel is in the tank? What is done to the truck? What will be done to the truck? Is a fuel system needed? ( I like the added filtration)
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 13 (permalink) Old 05-04-2011, 03:41 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
if its not out of your budget... maybe a Titan XL tank....
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #4 of 13 (permalink) Old 05-04-2011, 08:06 AM Thread Starter
Right now it has a bully dog 4"mbrp and intake. Soon to have efi and a trans for it.
auto83s is offline
post #5 of 13 (permalink) Old 05-04-2011, 01:28 PM
CRAZY CANUCK
an airdog160 or FASS system would be good to ensure you dont drain the fuel rails on big tunes, even the BD on the highest setting is probably draining the fuel rails and your not getting as much out of the engine as you should be, plus as Neel said the extra filtration is not a bad idea either
Ridin Dirty Club #5
TDG TOTQ
post #6 of 13 (permalink) Old 05-04-2011, 02:15 PM Thread Starter
Should I put a new fuel pump in the tank when I have it off? If I pul the bed I would like this to be the last time it comes off. Thanks.
auto83s is offline
post #7 of 13 (permalink) Old 05-04-2011, 02:18 PM Thread Starter
Also I saw that ppe makes a bigger fuel pickup is it worth installing that as well?
auto83s is offline
post #8 of 13 (permalink) Old 05-04-2011, 02:40 PM
CRAZY CANUCK
there is no in tank pump on these trucks, the CP3 injection pump does all the work(hence why an aftermarket pump is a good idea), if you install a FASS or Airdog they come with larger lines etc... thats all you really need to do
Ridin Dirty Club #5
TDG TOTQ
post #9 of 13 (permalink) Old 05-04-2011, 10:45 PM Thread Starter
Sending unit in these trucks are 465 bucks. Is it me or is that crazy?
auto83s is offline
post #10 of 13 (permalink) Old 05-04-2011, 11:10 PM
CRAZY CANUCK
depends where you shop.. from GM yes I believe it, dealers are probably the most expensive places to buy parts, way too rich for my blood
Ridin Dirty Club #5
TDG TOTQ
94 stroker .engine oil getting in fuel and back in to fuel tank powerstroking 1994-2003 7.3L Power Stroke 11 02-14-2011 04:11 AM
NO Fuel Guage READING for FRONT TANK of Dual Tank '94 F250 Ed50free 1994-2003 7.3L Power Stroke 5 03-08-2010 07:25 PM
what are some cheap up grades kc04 5.9L Cummins (2003-2007.5) 7 07-08-2007 03:57 AM
Fuel tank selector and rear fuel tank MUPPETHUNTER 1994-2003 7.3L Power Stroke 0 06-02-2007 07:24 PM
Hessitation up steep grades RancidRon 2003-2007 6.0L Power Stroke 2 02-06-2007 05:48 PM
