Couple simple questions - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Roughneck, this thread has received 2 replies and been viewed 1452 times.
post #1 of 3 (permalink) Old 05-07-2011, 06:38 PM Thread Starter
How do you reset the check oil light after changing the oil, it's been to long since I've had a chevy. Also my 04 with 200k is blowing greyish white smoke while idleing and driving, it runs fine though maybe a little rough at idle. When I bought it they said the injectors were replaced a couple years ago at a dealership. I've already changed the fuel filter air filter an oil, anybody got any ideas what it might be, thanks for any help.
94 Dodge 2500 4x4, single cab, auto with shift kit, CM flatbed, 35" coopers, Bilstein 5100s, black rims, bhaf, kdp tabbed, 300k miles, dipricol guages.
2011 Dodge 3500, single wheel cclb, ST, 4x4, cattleman bumpers, H&S 5" straight pipe, Mini Max, S&B intake, egr delete.
Roughneck is offline
post #2 of 3 (permalink) Old 05-08-2011, 06:07 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
not sure on the oil light reset.. i think its something like turn on the key and press the fuel pedal 3 times real quick...
As for the grey smoke on start up I would suggest you get your injector balance rates checked... smoke at idle usually indicates a bad injector or two
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
The Following User Says Thank You to BriteWhiteRam For this addition to TDG:
Roughneck (05-16-2011)
post #3 of 3 (permalink) Old 08-01-2011, 01:39 PM
Supporting Vendor
NickMA's Avatar
I agree on leaning toward injectors. In 2008 Bosch came out with the updated version of them, and since then we've had great luck with them.
If you look at balance rates, and pulse width you should be able to see if any are out of shape. I'd recomend changing at least 1 side at a time(it's pretty common to see injector issues in 01-04 trucks)
LB7 Injectors
LB7 Injector Install Kit
Nick Beaudoin
Merchant Automotive
http://www.merchant-automotive.com/
866-399-7169
[email protected]
NickMA is offline
a couple of questions billymac61 2003-2007 6.0L Power Stroke 1 04-02-2011 10:16 PM
couple questions oldkuntryboy 7.3L and 6.9 IDI (Pre 1994) 4 08-20-2010 11:14 AM
couple of questions on the 6.0 blackcloudCTD95 2003-2007 6.0L Power Stroke 11 03-18-2007 01:17 AM
got a couple of questions ThorsF350 General GM Truck Forum 2 11-17-2006 04:22 AM
Couple of 6.0 Questions. Smokin7.3 2003-2007 6.0L Power Stroke 4 08-23-2006 07:01 PM
