NEED SOME HELP ASAP - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stillcummin, this thread has received 7 replies and been viewed 1624 times.
post #1 of 8 (permalink) Old 08-02-2011, 02:18 AM Thread Starter
stillcummin's Avatar
NEED SOME HELP ASAP
I changed the fuel filter in my father n laws 01 2500 like I've done many times before but for some damn reason it just cranks n cranks I have fuel pressure at the bleeder screw I'm lost I know nothing about d-maxs I'm a 5.9 guy any info would be very very helpfull
BLACK 2013 RAM 3500HD BIGHORN EDTION
385hp/850tq AISIN TRANS, ALCOA WHEELS,ROUGH COUNTRY 2.5'' LEVELING KIT, WHEEL TO WHEEL STEPS,B&W TURN OVER BALL,DURAFLAP MUD FLAPS,TINTEDWINDOWS,RIDE RITE AIRBAGS,BIG TEX GRILLEGUARD, I'M SURE THERE WILL ALOT MORE TO COME SOONER OR LATER
stillcummin is offline
post #2 of 8 (permalink) Old 08-02-2011, 03:29 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
if you dont get the rubber o-ring seated just right you will get air in the fuel system, it sounds like you getting air from somewhere, is the bleed screw cracked, it is common for them to crack because they are plastic
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 8 (permalink) Old 08-02-2011, 12:21 PM Thread Starter
thanks for the reply, I'll check that, are these engines that hard to get primed back up I'm about to give up I've never had a cummins give this kind of problem just changin a fuel filter this is just crazy thanks for any help
post #4 of 8 (permalink) Old 08-03-2011, 01:59 AM
CRAZY CANUCK
I have never had an issue with mine but it is common for little things like that to give issues, you may also need to rebuild the filter head with some new seals, its pretty cheap and easy to do, just a PITA
Merchant sells kits to rebuild and fix the plastic bleed screw and the plastic WIF sensor as well, they are all known issues
http://www.merchant-automotive.com/d...ebuildkit.aspx
Ridin Dirty Club #5
TDG TOTQ
post #5 of 8 (permalink) Old 08-03-2011, 12:49 PM Thread Starter
thanks for the help goin to try again today
post #6 of 8 (permalink) Old 08-17-2011, 01:55 AM Thread Starter
I failed to mention that we also r&r the batteries the silly thing lost it memory to the ign some security device wasn't even a fuel prob at all guess it would have been helpful to give you guys all the info up front but still yet i've not had or seen this issue before have any of you guys??
post #7 of 8 (permalink) Old 08-18-2011, 12:04 AM
CRAZY CANUCK
its possible, the GM security can be hairy, I know you need a special by-pass module to use remote starters
Ridin Dirty Club #5
TDG TOTQ
post #8 of 8 (permalink) Old 08-18-2011, 03:38 AM Thread Starter
we had a local guy come down an brought his snap on scanner and in 30 mins he had it goin to bad we all dont have one of them 7000 dollar sanners layin around thanks for your time trying to help me gettin it goin
need some help ASAP vcassens 2003-2007 6.0L Power Stroke 4 08-13-2010 11:24 PM
Wtb ipr asap! JuststrokeIT Whats Been Sold 0 02-22-2009 04:41 PM
I Need Help Asap!!!! cowboyupp16 Duramax 2001-2004 (LB7) 2 01-26-2008 12:49 PM
Please Help! Asap!!!! imported_BigPSD 2003-2007 6.0 Tuner Forum 6 04-01-2007 11:48 AM
would like to know asap smokeisfun 5.9L Cummins 12 Valve (1994-1998.5) 10 03-11-2007 06:28 AM
