Injector warranty - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 03Duramax Newbie, this thread has received 6 replies and been viewed 2199 times.
post #1 of 7 (permalink) Old 09-07-2011, 03:42 PM Thread Starter
Injector warranty
Does anyone know if this warranty is transferrable???
03Duramax Newbie is offline
post #2 of 7 (permalink) Old 09-07-2011, 05:00 PM
Pardue the Traveler
New 0mega's Avatar
No, its not and The injector warranty is finished since its past the time allowed. Sorry
Singles Club member #250
New 0mega is offline
post #3 of 7 (permalink) Old 03-10-2012, 03:37 AM
hey did all 03 durmax have bad injectors thanks
2003 silverado 2500hd. 4x4 crewcab lb7 6.6 duramax
dusty is offline
post #4 of 7 (permalink) Old 03-11-2012, 04:07 PM
Pardue the Traveler
New 0mega's Avatar
yes '03 might have issues. it wasn't untill the '04.5's and the LLY did injector issues go away.
post #5 of 7 (permalink) Old 03-14-2012, 05:14 PM
injectors
in forestburg i have 132000k on this motor one owner says never had any trouble and nothing ever done to motor can u tell me app. how many kl. or miles they started having trouble thanks in adv.
dusty is offline
post #6 of 7 (permalink) Old 03-14-2012, 06:09 PM
Pardue the Traveler
New 0mega's Avatar
there is no set time line when the issues start. I don't know a whole lot about all the issues.
post #7 of 7 (permalink) Old 03-29-2012, 09:54 PM
All of the injectors on all LB7's were faulty. Around 08 or so they revised the check balls and ball seats. This fixed some issues. Cracked bodies are unpreventable and can happen at any time. My advice is to see if the truck has the latest injectors in it. If so and doing the work yourself, test the return rates individually and visually (safely) inspect for cracked bodies, then just replace the bad ones.
It is not technically a warranty. It was a special service policy, and yes it was transferable. GM knew they had a problem so they stood behind it. The policy is up on almost every truck, but if you need injectors, haggle the dealer a bit. Many are doing "in good faith" repairs at a fraction of the cost.
(2) 03 GMC EC/SB 4x4 SLT Duramax/Allison's
00 VW Jetta TDI/5spd
73 KW W923 NTC290
Durallymax is offline
200,000 mile injector warranty? thesmokinstroke02 Duramax 2001-2004 (LB7) 6 06-29-2009 05:46 PM
injector warranty jdreda Duramax 2001-2004 (LB7) 2 03-19-2008 10:18 AM
Injector Warranty Bone stock 99 Duramax 2001-2004 (LB7) 2 01-04-2008 03:36 AM
GM injector warranty? GM4ever Duramax 2001-2004 (LB7) 4 07-18-2007 11:08 AM
Do you think GM would honor the injector warranty if...... TheBac Duramax 2001-2004 (LB7) 3 09-07-2006 12:46 PM
