wont start? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moose03lb7crew, this thread has received 5 replies and been viewed 3892 times.
post #1 of 6 (permalink) Old 11-15-2011, 07:43 AM Thread Starter
wont start?
hi i am new to the forum and new to the diesel engine. i have an 03 2500hd that doesnt start. had the truck for bout half a year and ever since day one ive had issues with the fuel system. if it sat for a couple days i would have to prime it to start it but i didnt mind too much cuz it was rare that it sat that long... then i put bout 10,000 miles on it n it was losin a little power so i replaced the fuel filter couple weeks ago n it was back to normal. well my girlfriend drove it to work last week and she called n said it died. i knew she always ran vehicles low on fuel so i brought a fuel jug just in case but when i got there it had quarter tank so i ended up priming it and it ran fine. the next day she put fuel in it on her way to work and called me again sayin it died again so i primed it n it was fine for about five minutes and died.it did this 4 more times down the road until it got so bad that i could only keep it runnin if i kept the rpms above 1500. if it dropped below it would die. so i was tryin to baby it back to the house n it died altogether. i tried priming it again but wouldnt prime. so i got some ether (found out later i guess i shouldnt do that) n it ran for a couple seconds off the ether. so i rebuilt the fuel filter head and checked for cracks and now i can prime it, but now it doesnt start. it just cranks and doesnt even try to fire. the prime button goes soft after a couple minutes after pumping it hard. i hooked up my cheap scan tool and theres no codes. theres no air comin out of the bleeder screw when priming and i pushed on the schrader valve and its a steady bubble free stream of fuel. i am completely lost now cuz always worked on gassers. this is my first diesel. i also replaced the plastic bleed screw with a billet one just in case btw. The truck is also bone stock original. Any advice would b greatly appreciated
moose03lb7crew is offline
post #2 of 6 (permalink) Old 11-16-2011, 04:39 AM
CRAZY CANUCK
BriteWhiteRam's Avatar
If you're losing prime you have an airleak in the fuel system somewhere, it should never lose prime if the fuel system is air tight, may be a loose injector line....
Aaron the Crazy Canuck
Canadian Club Member #1
Singles Club member #186
Ridin Dirty Club #5
TDG TOTQ
BriteWhiteRam is offline
post #3 of 6 (permalink) Old 11-16-2011, 05:38 PM Thread Starter
Thanx, that will give me an idea what to start with. Gona put air to tank this weekend n c if i can c a leak.
post #4 of 6 (permalink) Old 11-17-2011, 03:22 AM Thread Starter
Put air to the tank tonight n heard massive air whistling from above the tank. Assuming rubber fuel lines need replaced. Check for sure tomorow
post #5 of 6 (permalink) Old 01-22-2012, 10:48 PM
I had a similar problem today. Truck still won't start. The code reader scanned 3 codes. P0335=Crankshaft Position A Circuit Malfunction, P1283 APP Sensor 2 circuit high voltage, P1639 5 volt reference 2 low. Any ideas?
Thanks,
lindy
Lindy02GMC
02 GMC 2500HD CrewCab 4x4
Green Metallic. Some cosmetic upgrades, MBRP 4" exhaust, Edge Juice w/Attitude, 20" Wolverines on 305/55/20 Nitto Terra Grapplers.
Lindy02GMC is offline
post #6 of 6 (permalink) Old 02-04-2012, 03:51 AM Thread Starter
The cp3 on my truck to a crap. Garage said wasnt putting out enough pressure to start... Dont know too much bout diesels but i think if theres somethin wrong with the crank or cam sensor the injectors wont fire?
Help! 01 Psd wont start joelykool 1994-2003 7.3L Power Stroke 2 05-31-2011 05:47 PM
wont start bsutton2000 1994-2003 7.3L Power Stroke 0 09-04-2009 09:49 PM
125 wont start sexytrkr ATV, UTV, Dirtbike Forum 5 04-03-2009 03:18 PM
wont start at all chevotaSS 6.5L Diesel Engine 37 02-29-2008 10:06 PM
