injector sleeve came out - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jdreda, this thread has received 4 replies and been viewed 3176 times.
post #1 of 5 (permalink) Old 04-16-2012, 09:59 PM Thread Starter
jdreda's Avatar
i am currently replacing my injectors and two of the sleeves came out. Does that mean i need to replace the sleeve or just some new o-rings? Plus how do the sleeves seal in the head?
jdreda is offline
post #2 of 5 (permalink) Old 04-16-2012, 11:05 PM
what engine are you working on?
broncobob is offline
post #3 of 5 (permalink) Old 04-17-2012, 05:13 PM
Pardue the Traveler
New 0mega's Avatar
Unless the cups are damaged, you can just replace the o-rings and press them back in the head. As for the correct way to press the cups back into the head, I'm not sure how to do that any more.
Singles Club member #250
New 0mega is offline
post #4 of 5 (permalink) Old 04-18-2012, 12:01 AM Thread Starter
jdreda's Avatar
working on 03 lb7
jdreda is offline
post #5 of 5 (permalink) Old 09-08-2013, 01:49 AM
There is a sealant you need for the sleeve or you will build pressure up in the coolant system and belch it everywhere.
Sent from AutoGuide.com Free App
Dawgfan is offline
wet sleeve Ironbrew Diesel Conversion 0 05-03-2010 05:13 PM
LB7 Fuel Injector Nozzle Tube Sleeve Replacement ripmf666 GM Spec Info 0 12-28-2008 09:30 AM
injector sleeve whitediesel23 2003-2007 6.0L Power Stroke 6 04-30-2008 02:41 AM
94 IDI turbo 7.3L sleeve or bore it? jap901 7.3L and 6.9 IDI (Pre 1994) 6 03-05-2008 02:02 AM
injector sleeve mudguy 1994-2003 7.3L Power Stroke 10 12-15-2007 11:34 AM
