2003 lb7 speedo guages - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wistlnwoodchuck, this thread has received 1 replies and been viewed 1886 times.
post #1 of 2 (permalink) Old 06-02-2012, 08:43 PM Thread Starter
HEY THERE, GAUGES SEEM TO BE NO LONGER WORKING ALSO NO INFO SCREEN EITHER.. IF I HIT THE DASH THEY COME BACK BUT THEN GONE AGAIN.. ANY EASY FIXES? THANX GUYS
peace
2004.5 GMCcc, sb, 4" straight pipe from turbo back, lly dmax, afe stage 1, 315 75 16 big o a/t, egr blocked ,billstiens all around,2 dvd's, nav, slt package,
wistlnwoodchuck is offline
post #2 of 2 (permalink) Old 06-04-2012, 06:09 PM
Pardue the Traveler
New 0mega's Avatar
sounds like a bad wire or bad connection or bad ground. first step check the condition of grounds, second check and make sure everything is plugged in tight. the third thing is to have a volt meter and start seeing where you loose power
Singles Club member #250
New 0mega is offline
The Following User Says Thank You to New 0mega For this addition to TDG:
wistlnwoodchuck (10-01-2012)
No Speedo 83RTS GM Transmissions 1 07-29-2012 03:09 AM
speedo mrsweattmt 1994-2003 7.3L Power Stroke 2 12-22-2010 11:57 PM
speedo??? Lil Boosty 2003-2007 6.0L Power Stroke 8 10-27-2009 12:14 PM
2003 international 9400 truck speedo moves with high low spilter tholdem Medium and Heavy Duty 8 07-24-2009 05:51 AM
Need speedo help on 07 F 250 firedude167 2003-2007 6.0L Power Stroke 8 07-06-2007 09:22 PM
