New to diesel trucks - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Tpeek, this thread has received 8 replies and been viewed 2333 times.
post #1 of 9 (permalink) Old 01-21-2013, 05:34 AM Thread Starter
So I will soon be purchasing my first Diesel truck, it's a 2001 Duramax 6.6 liter turbo diesel. it has a new programmer not sure on what brand but my brother in law say he paid $1000 for it. the truck has 131k miles and runs great, not sure what all has been done exhaust wise but its loud as ****. I joined the forum hoping to learn more about diesel engines and how to take good care of a Duramax truck. Also, I will be paying $10,000 for the truck and KBB value was $13.6k so I feel i'm getting a good deal. But if you guys could just let me know the typical maintenance for a diesel truck it would be much appreciated!
Tpeek is offline
post #2 of 9 (permalink) Old 01-21-2013, 12:30 PM
duramax maint.
. I don't do Darumax work but wanted to say welcome . What part of West Texas ? I went to high school in Iraan, on the Pecos River. . There are a lot of guys that are familiar with your truck. I do Fords, Cummins, etc. but never had to work on Duramax. C Ya around the forum.---Bob
broncobob is offline
post #3 of 9 (permalink) Old 01-21-2013, 04:24 PM Thread Starter
Thanks for the welcome Bob, and I am from San Angelo, not to be confused with San Antonio.
Tpeek is offline
post #4 of 9 (permalink) Old 01-21-2013, 08:18 PM
Pardue the Traveler
New 0mega's Avatar
well there is fluid changes, engine oil, transmission fluid, transfercase and axles, there is the filter changes, fuel filter (under hood), engine oil filter and external transmission filter. there is U-joints, brakes, greasing the steering components. there is tire wear and pressure you have to check
Singles Club member #250
New 0mega is offline
post #5 of 9 (permalink) Old 01-24-2013, 03:04 AM Thread Starter
I heard that you don't want to turn a diesel off if your like going into a store real quick or anything like that, because it needs to equalize or something. Anyone mind explaining that to me?
Tpeek is offline
post #6 of 9 (permalink) Old 01-24-2013, 07:55 AM
Hi Tpeek,
You don't want to shut down any turbo diesel engine that's been working under load before letting it idle for at least 2 minutes, this helps reduce the heat in the turbo reducing premature turbo failure, also wise to let the engine warm up when you start from cold, without excessive throttle use, allows the engine components & fluids to get to their proper working temperatures & viscosities, thus reducing premature wear.
James Snuggs is offline
post #7 of 9 (permalink) Old 01-24-2013, 12:22 PM Thread Starter
Perfectly explained. Thanks alot!
Tpeek is offline
post #8 of 9 (permalink) Old 01-24-2013, 04:42 PM
Pardue the Traveler
New 0mega's Avatar
but if you haven't been running the truck hard, and it is warmed up you should turn the truck off so you don't burn fuel needlessly.
The Following User Says Thank You to New 0mega For this addition to TDG:
merlin5577 (06-07-2013)
post #9 of 9 (permalink) Old 01-24-2013, 05:05 PM
. Ihave a good friend in sSan Angelo. I worked at the international dealer there long ago! Anyway , you have plenty of info. C Ya./---Bob
I'm new to diesel trucks..... Djanusz85 General Ford Truck and Excursion 0 03-17-2011 05:03 PM
Socal Diesel Trucks at Fontana Diesel Drags gasuout Southwest 0 07-11-2010 08:53 PM
New to Diesel trucks BlueCake General Dodge Discussion 1 04-01-2009 02:32 PM
new to the diesel trucks 1bAdmAx Duramax 2001-2004 (LB7) 4 02-13-2008 12:27 AM
New Diesel Trucks Nolafishr Duramax 07.5-2010 (LMM) 15 12-04-2007 09:17 PM
