04 Duramax Allison doesn't go in reverse - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Weld engineer, this thread has received 2 replies and been viewed 4389 times.
post #1 of 3 (permalink) Old 10-14-2013, 02:00 AM Thread Starter
Weld engineer's Avatar
Dad's 04 Dmax did something new today. He put it in reverse and it didn't go. Didn't rev it afraid it would slip in gear and slam back. Put it in drive and move a little then back to reverse and it took that time. Truck is newer to him and just recently started towing his 5th wheel. Any one have this experience or thoughts on it? His previous truck was a '75 Chevy with three speed and no overdrive (400 I think) so he figures an additive is needed because he figures it's a sticky valve. Got him to hold off on that for now.
Early 2004 F-250 4x4 CC 6.0
Weld engineer is offline
post #2 of 3 (permalink) Old 10-14-2013, 02:16 AM
Aimless Wanderer
Check and clean the electrical master connector on the side of the trans. Drop the pan, change filter and oil. Sounds like it's in the beginning stages of solenoid and/or valve body failure. Rostra is the manufacturer of the solenoids and they do sell direct a lot less expensive then the dealership.
The question I seek an answer for is simply; why, or why not?
Backslap is offline
The Following User Says Thank You to Backslap For this addition to TDG:
Weld engineer (10-14-2013)
post #3 of 3 (permalink) Old 11-07-2013, 04:59 AM
I had the same problem with my '02. The torque lock-up solenoid will start to fail as it warms up. Trans shop in Salmon Arm B.C. scoped and found it. Dropped pan and removed solenoid and tested. Failed after warming with a heat gun. Hasn't missed a shift since.
hdgeorge is offline
The Following User Says Thank You to hdgeorge For this addition to TDG:
Weld engineer (11-07-2013)
Duramax and Allison Training courses? Omar GM Performance Forum 0 04-22-2012 05:10 AM
05 International 4300/ Allison 2200 RDS: No reverse lights Rocketship Medium and Heavy Duty 0 05-25-2011 01:14 PM
Duramax/Allison stuck in gear! Sparks280zt Duramax 2001-2004 (LB7) 5 03-26-2010 02:13 PM
2007 Chevy Duramax Allison CC sqrl$$ Whats Been Sold 1 05-26-2009 02:15 AM
Duramax/Allison Nolafishr Duramax 07.5-2010 (LMM) 8 12-31-2007 02:34 AM
