Intermintent Low Oil pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by CatHouseMouse, this thread has received 1 replies and been viewed 2376 times.
post #1 of 2 (permalink) Old 08-22-2014, 02:47 PM Thread Starter
CatHouseMouse's Avatar
I am having a low oil pressure issue and cant seem to figure it out. Happens when the engine is at operating temp, the oil pressure will vary between 30 and 60 pounds at speed and 8 and 30 at idle. In fact it will set off the low oil pressure warning at idle. Have already changed the sensor with no luck. I know I need to get a manual gauge on it. Is there a T fitting made so could run both gauges at the same time so they can be compared to each other? Or is there another place to sample the pressure from? Ideas? Mike.
CatHouseMouse is offline
post #2 of 2 (permalink) Old 04-26-2015, 04:46 AM
KerrDiesel's Avatar
My first thought is your dash cluster.
KerrDiesel is offline
Low Oil Pressure slednek8 Duramax 2006-2007(LBZ & LLY) 17 06-28-2015 11:19 PM
Low oil pressure garebel 5.9L Cummins 12 Valve (1994-1998.5) 2 11-20-2009 01:36 AM
low oil pressure mani 2003-2007 6.0L Power Stroke 8 07-08-2009 02:55 AM
Low Oil Pressure Diezel Dawg 1994-2003 7.3L Power Stroke 8 01-16-2007 11:15 AM
Any way to boost Low pressure oil pressure? CSIPSD 1994-2003 7.3L Power Stroke 6 10-10-2006 01:15 AM
