02 MAX NO START - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MANNCLAN, this thread has received 0 replies and been viewed 1339 times.
post #1 of 1 (permalink) Old 03-08-2015, 11:10 PM Thread Starter
02 MAX NO START
I know this issue has been addressed numerous times, but I need some more info.
My son in law has an 02 LB7 that will not start without a shot of ether, I know that's not good, but it's the only way. We have rebuilt the filter head and replaced the fuel line to the test port, but it's still getting air from somewhere. My Autoenginuity scantool gives me 2 codes po1094 fuel rail pressure low at idle and decel defuel, and po380 glow plug circuit A malfunction. When switching to the live data mode the injector balance is within limits, rail pressure when cranking is about 700psi and around 4400 at idle, as it comes off idle the rail pressure runs pretty even with the desired rail pressure. I maintain that we cannot even think about high pressure problems at idle until the system is airtight. Is this a valid assumption? Also, what is the minimum rail pressure required for fuel command from the electronics?Thanks in advance.
MANNCLAN is offline
H&S MINI MAX OR BLACK MAX ANY USERS? trucks2u 2008-2010 6.4L Engine Tuner Forum 9 10-26-2010 11:46 AM
Max hp Max power! with SCT Hybrid_4x4_Superduty 2003-2007 6.0 Tuner Forum 21 02-16-2009 02:29 AM
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 09:00 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 11:55 AM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 07:32 AM
