fuel test port - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dusty, this thread has received 2 replies and been viewed 681 times.
post #1 of 3 (permalink) Old 04-20-2018, 04:24 PM Thread Starter
fuel test port
the lb7 s have a fuel test port by the alternator can anyone tell me the make orpart number for the FEMALE HALF QUICK CONNECTOR THAT FITS THIS PORT THANKS IN ADVANCE
2003 silverado 2500hd. 4x4 crewcab lb7 6.6 duramax
dusty is offline
post #2 of 3 (permalink) Old 04-21-2018, 01:56 AM
Jasong's Avatar
I don't know the part but the hose and gauge will have to be rated for 30 thousand PSI.$$$
If your are looking to check rail pressure a BAFX OBDII Bluetooth module ($35) and the app Torque (Pro $9) will do that much better. (Injector balance rates, boost etc.)
Just my 2
Jasong is offline
post #3 of 3 (permalink) Old 04-21-2018, 04:10 AM Thread Starter
test port
hi i think its a low vacuum reading on that port i think i will cut into the fuel line on the out let side of the fuel filter then run a vacuum line into the cab 4 my feading thanks
dusty is offline
Square Port Or Round Port?? Cat Attack Medium and Heavy Duty 6 05-07-2015 09:55 PM
Obd port or no obd port 1993 f350 7.3 no turbo hobbieman 7.3L and 6.9 IDI (Pre 1994) 2 02-08-2014 03:22 PM
Oil press. test port? lilpooh 2003-2007 6.0L Power Stroke 4 07-29-2010 04:50 AM
tranny test port thread size? Darsey715 2003-2007 6.0L Power Stroke 3 02-19-2010 11:47 PM
fuel pressure port loacation?? jschall 2003-2007 6.0L Power Stroke 8 08-08-2006 05:13 PM
