EGT gauge stuck? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tahoedmax, this thread has received 6 replies and been viewed 1865 times.
post #1 of 7 (permalink) Old 04-19-2007, 07:44 AM Thread Starter
diesel idiot
EGT gauge stuck?
Tonight on the freeway my EGT was bouncing all over the place and then it stuck at 800. It worked fine all yesterday and all day today. There are no loose connections, ground is good, any ideas on what this could be? Maybe not letting the gauge orient when I started my truck quickly? HELPPPPP
2004 Chevy CC/SB LB7 LT3
EFILive, SC Trans w/ 1058 by me, Traction bars and centerlink braces built by me, Custom adjustable stock wastegate, 6 inch custom exhaust, 1792 Lift Pump, Belltech 3" drop shackles, Black H2's w/ Falken 285/60/17s for summer, BFG 315/70/17s for winter, SD sleeves, DiPricol EGT and Boost gauges on the pillar along with an Aeroforce for rail PSI and trans temp, 2 Kicker Comp CVT 10's w/ memphis amp, t-rex full face billet grille,limo tint, .Oh yeah I'm 20 and I built and tuned it myself.
tahoedmax is offline
post #2 of 7 (permalink) Old 04-19-2007, 12:03 PM
Maybe check to see if the pyro wire was accidentally shorting against something? You do state you were "bouncing all over the place"...
TheBac is offline
post #3 of 7 (permalink) Old 04-19-2007, 06:04 PM Thread Starter
diesel idiot
What do you mean shorting against something? It works normally intermitantly, but then tends to stick at one temperature. The odd part is that it worked normally for two days or so.
post #4 of 7 (permalink) Old 04-20-2007, 04:36 AM
i had a similar problem and mine was a bad piro in the manifold
slcdmax is offline
post #5 of 7 (permalink) Old 04-20-2007, 05:41 AM Thread Starter
diesel idiot
The thing is though that mine worked for a few days prior to it going crazy. Now the gauge is totally unresponsive, and my vendor said that its most likely the gauge if the needle isnt moving and once was, so theyre sending me a new one. Do you mean the pyro was bad or you hooked it up incorrectly?
post #6 of 7 (permalink) Old 04-20-2007, 07:43 AM
no the pyro probe just went bad
slcdmax is offline
post #7 of 7 (permalink) Old 04-20-2007, 05:19 PM Thread Starter
diesel idiot
Now my gauge doesnt even move at all. The needle bounces like it wants to move, but it just wont, which makes me think its the gauge. It kind of slowly just puked out, and I think its the stepper motor. Hopefully my new egt comes soon because I want to crank up my quadzilla :evil:
Closed Thread
