Need Some Advice - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lb7man08, this thread has received 7 replies and been viewed 697 times.
post #1 of 8 (permalink) Old 04-08-2008, 03:30 AM Thread Starter
Afrye
Need Some Advice
Gonna try the PPE boost vavle, just wanting some feed back.
02 4-Door Dually Duramax, Eagle Alloy Wheels, Western Diesel Boost & Pyro Gauges,BD Dual Exhaust, BD Cold Air Intake, Juice with Attitude, Hot unlock, PPE boost vavle, soon to have BD full bore manifold,and eventually a tranny!
lb7man08 is offline
post #2 of 8 (permalink) Old 04-08-2008, 10:44 AM
TDG Mafia # 81
Horsehaulin's Avatar
I am in the same boat, so I am looking to see what the replies are now. I am running EFI Live but am not getting the boost that I want so I either need the PPE Boost Valve, or a new wastegate.
Tony
Wish I could've helped, but I am where you are.
Horsehaulin is offline
post #3 of 8 (permalink) Old 04-30-2008, 03:13 AM Thread Starter
Afrye
I put my boost vavle on the other day, It didnt make a difference tell 3rd gear, i went from 26-27psi to 30psi in 3-5 locked gears, it cleans up the smoke a little more now :shrug:
lb7man08 is offline
post #4 of 8 (permalink) Old 04-30-2008, 04:23 AM
The amount of boost you are going to see will increase with every upshift. I wouldn't go above 34 psi in 5th or 6th, that seems to be the max that the turbo can handle. Mine hits 32-33 in 6th and I've had it for close to 20k mi. and still get the same boost. I decided to go with the adjustable w/g actuator for the adjustability and larger diaphragm - I get more boost sooner (lower rpm) than with the stocker.
mckey73 is offline
post #5 of 8 (permalink) Old 05-01-2008, 01:18 AM Thread Starter
Afrye
what kind did you put on, cause mine wont hold 29 it'll just bounce on and off, what programing do u have?
lb7man08 is offline
post #6 of 8 (permalink) Old 05-01-2008, 01:23 AM
TDG Mafia # 81
Stock programming will limit the amount of boost due to factory settings. I personally am running EFI Live for tuning and tuning myself with some help from some vets of EFI Live. Once I get my trans in next week, look out 500RWHP cause here I come!
Tony
post #7 of 8 (permalink) Old 05-01-2008, 03:10 AM
I use ppe tuning and a banks actuator that has been made to work as it should.
mckey73 is offline
post #8 of 8 (permalink) Old 05-02-2008, 12:08 AM
TDG Mafia # 81
Was there something wrong with the Banks Actuator? Help me out as I am thinking of either a Banks or BD.
Tony
