02 LB7 Rebuild for 3500HD - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ripmf666, this thread has received 8 replies and been viewed 3485 times.
post #1 of 9 (permalink) Old 12-25-2008, 11:14 AM Thread Starter
Mafia member #105
ripmf666's Avatar
Send a message via AIM to ripmf666 Send a message via Yahoo to ripmf666
02 LB7, .20 over 15 to 1 Socal Diesel cut and coated pistons and Crower rods,ARP Head and Main studs.Socal dampener,45% over injectors.
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins installed by BigDipper,PPE lift pump, BigDipper 30% injectors, BigDipper Trans Precion ML converter.PPE Twin Cp3's.
Alot Of thanks To Kat & Pat at duramax diesels, Joe & Dan at PPE,George aka BigDipper
RIP LBZ 6/1/[email protected]:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
http://www.dieselbuilder.com/Media/P...adoBuild_2.pdf
ripmf666 is offline
post #2 of 9 (permalink) Old 12-25-2008, 11:16 AM Thread Starter
Mafia member #105
ripmf666's Avatar
She's Alive again
ripmf666 is offline
post #3 of 9 (permalink) Old 12-25-2008, 11:17 AM Thread Starter
Mafia member #105
ripmf666's Avatar
We got this motor already built,My friend had his machinist friend do the build, Went and picked it up he never bagged it up, He wasted the time bagging it up for the ride home in my truck. Once here we un bagged it and it had metal dust all over the inside so we had to take it back apart, We ended up finding that he never even polished the crank and the rod bearings had scratchs in them. Also when he went to get all the weights for the balancing he just moved the pistons around and mixed the rods and all till it was matched. We figured he had the rods and piston right we should of thought and looked closer, This is how he had installed the pistons pics below.
She's Alive again
ripmf666 is offline
post #4 of 9 (permalink) Old 12-25-2008, 11:20 AM Thread Starter
Mafia member #105
ripmf666's Avatar
wasn't sure how much was different with the right to left on a Dmax, I called Guy and he said there is 30 thousands offset.This motor was already built once heads on and tqed,When I picked it up for my friend it was in the machine shop next to a mill that was running the motor had metal shavings stuck all over the rods and crank and bottom of the pistons,We tore it apart and found the crank was not turned and the bearings were scratched,Did not give 2 thoughts of the pistons since he had balanced it all he did was match the weights by swapping the pisons around and when we put everything back and then looked and felt dumb to see that 4 pistons were in the wrong hole.All is fixed now, Guess it was a good thing we took it apart from seeing the shavings since the heads were already on, Sucks for him that he has to get new head gaskets again and had to get new rod bearings. Better safe then sorry.
I will have more pics in a few days were almost finished with this truck.
She's Alive again
ripmf666 is offline
post #5 of 9 (permalink) Old 12-25-2008, 04:28 PM
Gone Fishin...
merlin5577's Avatar
Awesome pictures and great info! Hope everything works out for you. Thanks for sharing.
One question though; The first post says 15 to 1 pistons, why the change? Arent stock LB7s 17.5 to 1? So why the change? Thanks!
-Robert.
My Fleet;
1997 GMC Suburban SLT 5.7L 4A
Reading material
I am an old Fart;
Toot-Toot
merlin5577 is offline
post #6 of 9 (permalink) Old 12-25-2008, 09:16 PM Thread Starter
Mafia member #105
ripmf666's Avatar
Yes factory was 17.5 to 1 then the later LLY and LBZ's went to 16.8 to 1. With the lower compression you can run some more boost and also by deliping the pistons helps direct the fuel spray better into the bowl to get a better burn.
She's Alive again
ripmf666 is offline
post #7 of 9 (permalink) Old 12-26-2008, 08:18 PM
Gone Fishin...
merlin5577's Avatar
Alright, I understand that, but wouldnt the higher compression with more boost create more power?
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
post #8 of 9 (permalink) Old 12-26-2008, 11:05 PM Thread Starter
Mafia member #105
ripmf666's Avatar
That also would cause more heat that we do not need lower the compression and we can twist more rpm and raise the HP and loose some TQ,Its give and take.
She's Alive again
ripmf666 is offline
post #9 of 9 (permalink) Old 12-27-2008, 01:16 AM
Gone Fishin...
merlin5577's Avatar
Gotcha. Thanks!
-Robert.
My Fleet;
Reading material
I am an old Fart;
Toot-Toot
06 Duramax rebuild and install thread ripmf666 Duramax 2006-2007(LBZ & LLY) 44 01-05-2009 04:23 AM
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 10:55 PM
HG Rebuild Pat M 2003-2007 6.0L Power Stroke 1 12-23-2008 02:42 PM
e4od rebuild thread camojeeper Ford - Modification instructions, Product installs and Tech Articles 0 12-23-2008 03:00 AM
